FIX: Some brittle tests with hardcoded ids
If we’re going to use hardcoded ids, we should make sure the records are not saved, or that the ID will not come up during normal use.
diff --git a/app/models/category.rb b/app/models/category.rb
index 45aac78..a991178 100644
--- a/app/models/category.rb
+++ b/app/models/category.rb
@@ -113,6 +113,9 @@ class Category < ActiveRecord::Base
   # we may consider wrapping this in another spot
   attr_accessor :displayable_topics, :permission, :subcategory_ids, :notification_level, :has_children
+  # Allows us to skip creating the category definition topic in tests.
+  attr_accessor :skip_category_definition
   @topic_id_cache = DistributedCache.new('category_topic_ids')
   def self.topic_ids
@@ -212,6 +215,8 @@ class Category < ActiveRecord::Base
   def create_category_definition
+    return if skip_category_definition
     t = Topic.new(title: I18n.t("category.topic_prefix", category: name), user: user, pinned_at: Time.now, category_id: id)
     t.skip_callbacks = true
     t.ignore_category_auto_close = true
diff --git a/spec/models/report_spec.rb b/spec/models/report_spec.rb
index b0ddc29..fa6395a 100644
--- a/spec/models/report_spec.rb
+++ b/spec/models/report_spec.rb
@@ -1,6 +1,10 @@
 require 'rails_helper'
 describe Report do
+  let(:c0) { Fabricate(:category, skip_category_definition: true) }  # id: 3
+  let(:c1) { Fabricate(:category, parent_category: c0, skip_category_definition: true) }  # id: 2
+  let(:c2) { Fabricate(:category, skip_category_definition: true) }  # id: 4
   shared_examples 'no data' do
     context "with no data" do
       it 'returns an empty report' do
@@ -16,13 +20,6 @@ describe Report do
   shared_examples 'category filtering on subcategories' do
-    before do
-      c = Fabricate(:category, id: 3)
-      c.topic.destroy
-      c = Fabricate(:category, id: 2, parent_category_id: 3)
-      c.topic.destroy
-      # destroy the category description topics so the count is right, on filtered data
-    end
     it 'returns the filtered data' do
       expect(report.total).to eq(1)
@@ -753,7 +750,7 @@ describe Report do
       before(:each) do
         user = Fabricate(:user)
         post0 = Fabricate(:post)
-        post1 = Fabricate(:post, topic: Fabricate(:topic, category_id: 2))
+        post1 = Fabricate(:post, topic: Fabricate(:topic, category: c1))
         post2 = Fabricate(:post)
         post3 = Fabricate(:post)
         PostAction.act(user, post0, PostActionType.types[:off_topic])
@@ -765,12 +762,12 @@ describe Report do
       context "with category filtering" do
-        let(:report) { Report.find('flags', category_id: 2) }
+        let(:report) { Report.find('flags', category_id: c1.id) }
         include_examples 'category filtering'
         context "on subcategories" do
-          let(:report) { Report.find('flags', category_id: 3) }
+          let(:report) { Report.find('flags', category_id: c0.id) }
           include_examples 'category filtering on subcategories'
@@ -788,18 +785,18 @@ describe Report do
       before(:each) do
         Fabricate(:topic)
-        Fabricate(:topic, category_id: 2)
+        Fabricate(:topic, category: c1)
         Fabricate(:topic)
         Fabricate(:topic, created_at: 45.days.ago)
-        let(:report) { Report.find('topics', category_id: 2) }
+        let(:report) { Report.find('topics', category_id: c1.id) }
-          let(:report) { Report.find('topics', category_id: 3) }
+          let(:report) { Report.find('topics', category_id: c0.id) }
@@ -876,7 +873,7 @@ describe Report do
       before(:each) do
         topic = Fabricate(:topic)
-        topic_with_category_id = Fabricate(:topic, category_id: 2)
+        topic_with_category_id = Fabricate(:topic, category: c1)
         Fabricate(:post, topic: topic)
         Fabricate(:post, topic: topic_with_category_id)
@@ -884,12 +881,12 @@ describe Report do
-        let(:report) { Report.find('posts', category_id: 2) }
+        let(:report) { Report.find('posts', category_id: c1.id) }
-          let(:report) { Report.find('posts', category_id: 3) }
+          let(:report) { Report.find('posts', category_id: c0.id) }
@@ -908,19 +905,19 @@ describe Report do
       include_examples 'with data x/y'
       before(:each) do
         Fabricate(:post, topic: Fabricate(:topic))
         Fabricate(:topic)
-        let(:report) { Report.find('topics_with_no_response', category_id: 2) }
+        let(:report) { Report.find('topics_with_no_response', category_id: c1.id) }
-          let(:report) { Report.find('topics_with_no_response', category_id: 3) }
+          let(:report) { Report.find('topics_with_no_response', category_id: c0.id) }
@@ -937,11 +934,11 @@ describe Report do
       before(:each) do
-        topic = Fabricate(:topic, category_id: 2)
+        topic = Fabricate(:topic, category: c1)
         post = Fabricate(:post, topic: topic)
         PostAction.act(Fabricate(:user), post, PostActionType.types[:like])
-        topic = Fabricate(:topic, category_id: 4)
+        topic = Fabricate(:topic, category: c2)
@@ -951,12 +948,12 @@ describe Report do
-        let(:report) { Report.find('likes', category_id: 2) }
+        let(:report) { Report.find('likes', category_id: c1.id) }
-          let(:report) { Report.find('likes', category_id: 3) }
+          let(:report) { Report.find('likes', category_id: c0.id) }
GitHub sha: e75b2403
