Fix specs
diff --git a/spec/multisite/s3_store_spec.rb b/spec/multisite/s3_store_spec.rb
index 7939f32..e95de89 100644
--- a/spec/multisite/s3_store_spec.rb
+++ b/spec/multisite/s3_store_spec.rb
@@ -4,7 +4,6 @@ require 'file_store/s3_store'
 RSpec.describe 'Multisite s3 uploads', type: :multisite do
   let(:uploaded_file) { file_from_fixtures("smallest.png") }
   let(:upload_sha1) { Digest::SHA1.hexdigest(File.read(uploaded_file)) }
-  let(:upload) { Fabricate(:upload, sha1: upload_sha1) }
   context 'uploading to s3' do
     before(:each) do
@@ -21,16 +20,16 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
       it "returns the correct url for default and second multisite db" do
         test_multisite_connection('default') do
-          test_upload = Fabricate(:upload, sha1: upload_sha1)
-          expect(store.store_upload(uploaded_file, test_upload)).to eq(
+          upload = Fabricate(:upload, sha1: upload_sha1)
+          expect(store.store_upload(uploaded_file, upload)).to eq(
             "//#{SiteSetting.s3_upload_bucket}.s3.dualstack.us-east-1.amazonaws.com/uploads/default/original/1X/c530c06cf89c410c0355d7852644a73fc3ec8c04.png"
           expect(upload.etag).to eq("ETag")
         test_multisite_connection('second') do
             "//#{SiteSetting.s3_upload_bucket}.s3.dualstack.us-east-1.amazonaws.com/uploads/second/original/1X/c530c06cf89c410c0355d7852644a73fc3ec8c04.png"
@@ -57,6 +56,7 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
       it "removes the file from s3 on multisite" do
           store.expects(:get_depth_for).with(upload.id).returns(0)
           s3_helper.expects(:s3_bucket).returns(s3_bucket).at_least_once
           upload.update_attributes!(url: "//s3-upload-bucket.s3.dualstack.us-west-1.amazonaws.com/uploads/default/original/1X/#{upload.sha1}.png")
@@ -73,6 +73,7 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
       it "removes the file from s3 on another multisite db" do
           upload.update_attributes!(url: "//s3-upload-bucket.s3.dualstack.us-west-1.amazonaws.com/uploads/second/original/1X/#{upload.sha1}.png")
@@ -94,6 +95,7 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
             upload.update_attributes!(url: "//s3-upload-bucket.s3.dualstack.us-west-1.amazonaws.com/discourse-uploads/uploads/default/original/1X/#{upload.sha1}.png")
GitHub sha: 0947fa2b
