FIX: 'status' param change not filtering the topics in tag route.
FIX: ‘status’ param change not filtering the topics in tag route.
Use existing ‘filterQueryParams’ helper method to set ‘queryParams’ value for tag route.
diff --git a/app/assets/javascripts/discourse/routes/tags-show.js.es6 b/app/assets/javascripts/discourse/routes/tags-show.js.es6
index a538c4f..49a4231 100644
--- a/app/assets/javascripts/discourse/routes/tags-show.js.es6
+++ b/app/assets/javascripts/discourse/routes/tags-show.js.es6
@@ -1,15 +1,16 @@
 import Composer from "discourse/models/composer";
 import showModal from "discourse/lib/show-modal";
-import { findTopicList } from "discourse/routes/build-topic-route";
+import {
+  filterQueryParams,
+  findTopicList
+} from "discourse/routes/build-topic-route";
+import { queryParams } from "discourse/controllers/discovery-sortable";
 import PermissionType from "discourse/models/permission-type";
 export default Discourse.Route.extend({
   navMode: "latest",
-  queryParams: {
-    ascending: { refreshModel: true },
-    order: { refreshModel: true }
+  queryParams,
   renderTemplate() {
     const controller = this.controllerFor("tags.show");
@@ -69,10 +70,7 @@ export default Discourse.Route.extend({
     controller.set("loading", true);
-    const params = controller.getProperties("order", "ascending");
-    params.order = transition.to.queryParams.order || params.order;
-    params.ascending = transition.to.queryParams.ascending || params.ascending;
+    const params = filterQueryParams(transition.to.queryParams, {});
     const categorySlug = this.categorySlug;
     const parentCategorySlug = this.parentCategorySlug;
     const filter = this.navMode;
GitHub sha: 56b77777
