FIX: Support Ruby 3 keyword arguments (PR #14516)
This pull request supports Ruby 3 keyword argument.
Example without this change
$ ruby -v
ruby 3.0.2p107 (2021-07-07 revision 0db68f0233) [x86_64-linux]
$ bundle exec rspec ./spec/lib/site_settings/validations_spec.rb:107
Run options: include {:locations=>{"./spec/lib/site_settings/validations_spec.rb"=>[107]}}
Randomized with seed 27763
F
Failures:
  1) SiteSettings::Validations s3 buckets reusage #validate_s3_upload_bucket cannot be made blank unless the setting is false
     Failure/Error:
       @redis.scan_each(options).map do |key|
         key = remove_namespace(key) if @namespace
         key
     ArgumentError:
       wrong number of arguments (given 1, expected 0)
     # ./lib/discourse_redis.rb:102:in `block in scan_each'
     # ./lib/discourse_redis.rb:29:in `ignore_readonly'
     # ./lib/discourse_redis.rb:86:in `scan_each'
     # ./lib/cache.rb:46:in `keys'
     # ./app/models/report.rb:135:in `clear_cache'
     # ./config/initializers/014-track-setting-changes.rb:32:in `block in <main>'
     # ./lib/discourse_event.rb:14:in `block in trigger'
     # ./lib/discourse_event.rb:13:in `trigger'
     # ./spec/support/discourse_event_helper.rb:5:in `trigger'
     # ./lib/site_setting_extension.rb:370:in `add_override!'
     # ./lib/site_setting_extension.rb:537:in `block in setup_methods'
     # ./spec/lib/site_settings/validations_spec.rb:108:in `block (4 levels) in <top (required)>'
     # ./spec/rails_helper.rb:279:in `block (2 levels) in <top (required)>'
Finished in 0.16988 seconds (files took 2.55 seconds to load)
1 example, 1 failure
Failed examples:
rspec ./spec/lib/site_settings/validations_spec.rb:107 # SiteSettings::Validations s3 buckets reusage #validate_s3_upload_bucket cannot be made blank unless the setting is false
Example with this change
$ ruby -v
Randomized with seed 22075
Finished in 0.16971 seconds (files took 2.41 seconds to load)
1 example, 0 failures
Fixed spec failures with Ruby 3
Compared rspec result between main branch and this branch, this commit addresses these 259 failures.
rspec ./spec/lib/site_settings/validations_spec.rb:99 # SiteSettings::Validations s3 buckets reusage #validate_s3_upload_bucket should raise an error when the 's3_upload_bucket' is a subdirectory of 's3_backup_bucket'
rspec ./spec/lib/site_settings/validations_spec.rb[1:2:2:1:4] # SiteSettings::Validations s3 buckets reusage #validate_s3_upload_bucket behaves like s3 bucket validation should raise an error when both buckets are equal
rspec ./spec/lib/site_settings/validations_spec.rb[1:2:2:1:5] # SiteSettings::Validations s3 buckets reusage #validate_s3_upload_bucket behaves like s3 bucket validation should raise an error when both buckets are equal except for a trailing slash
rspec ./spec/lib/site_settings/validations_spec.rb[1:2:2:1:3] # SiteSettings::Validations s3 buckets reusage #validate_s3_upload_bucket behaves like s3 bucket validation shouldn't raise an error when both buckets are equal, but use a different path
rspec ./spec/components/post_creator_spec.rb:1271 # PostCreator doesn't strip starting whitespaces
rspec ./spec/components/post_creator_spec.rb:23 # PostCreator new topic can create a topic with null byte central
rspec ./spec/components/post_creator_spec.rb:29 # PostCreator new topic can be created with auto tracking disabled
rspec ./spec/components/post_creator_spec.rb:35 # PostCreator new topic can be created with first post as wiki
rspec ./spec/components/post_creator_spec.rb:43 # PostCreator new topic can be created with a hidden reason
rspec ./spec/components/post_creator_spec.rb:52 # PostCreator new topic ensures the user can create the topic
rspec ./spec/components/post_creator_spec.rb:57 # PostCreator new topic can be created with custom fields
rspec ./spec/components/post_creator_spec.rb:63 # PostCreator new topic reply to post number omits reply to post number if received on a new topic
rspec ./spec/components/post_creator_spec.rb:72 # PostCreator new topic invalid title has errors
rspec ./spec/components/post_creator_spec.rb:81 # PostCreator new topic invalid raw has errors
rspec ./spec/components/post_creator_spec.rb:90 # PostCreator new topic success is not hidden
rspec ./spec/components/post_creator_spec.rb:98 # PostCreator new topic success doesn't return true for spam
rspec ./spec/components/post_creator_spec.rb:103 # PostCreator new topic success triggers extensibility events
rspec ./spec/components/post_creator_spec.rb:119 # PostCreator new topic success does not notify on system messages
rspec ./spec/components/post_creator_spec.rb:131 # PostCreator new topic success enqueues job to generate messages
rspec ./spec/components/post_creator_spec.rb:136 # PostCreator new topic success generates the correct messages for a secure topic
rspec ./spec/components/post_creator_spec.rb:180 # PostCreator new topic success generates the correct messages for a normal topic
rspec ./spec/components/post_creator_spec.rb:207 # PostCreator new topic success extracts links from the post
rspec ./spec/components/post_creator_spec.rb:213 # PostCreator new topic success queues up post processing job when saved
rspec ./spec/components/post_creator_spec.rb:235 # PostCreator new topic success passes the invalidate_oneboxes along to the job if present
rspec ./spec/components/post_creator_spec.rb:242 # PostCreator new topic success passes the image_sizes along to the job if present
rspec ./spec/components/post_creator_spec.rb:250 # PostCreator new topic success assigns a category when supplied
rspec ./spec/components/post_creator_spec.rb:254 # PostCreator new topic success adds  meta data from the post
rspec ./spec/components/post_creator_spec.rb:258 # PostCreator new topic success passes the image sizes through
rspec ./spec/components/post_creator_spec.rb:263 # PostCreator new topic success sets topic excerpt if first post, but not second post
rspec ./spec/components/post_creator_spec.rb:273 # PostCreator new topic success supports custom excerpts
rspec ./spec/components/post_creator_spec.rb:288 # PostCreator new topic success creates post stats
rspec ./spec/components/post_creator_spec.rb:304 # PostCreator new topic success updates topic stats
rspec ./spec/components/post_creator_spec.rb:313 # PostCreator new topic success creates a post with featured link
rspec ./spec/components/post_creator_spec.rb:322 # PostCreator new topic success allows notification email to be skipped
rspec ./spec/components/post_creator_spec.rb:339 # PostCreator new topic success topic's auto close doesn't update topic's auto close when it's not based on last post
rspec ./spec/components/post_creator_spec.rb:367 # PostCreator new topic success topic's auto close topic's auto close based on last post updates topic's auto close date
rspec ./spec/components/post_creator_spec.rb:388 # PostCreator new topic success topic's auto close topic's auto close based on last post when auto_close_topics_post_count has been reached closes the topic and deletes the topic timer
rspec ./spec/components/post_creator_spec.rb:409 # PostCreator new topic success topic's auto close topic's auto close based on last post when auto_close_topics_post_count has been reached uses the system locale for the message
rspec ./spec/components/post_creator_spec.rb:434 # PostCreator new topic success topic's auto close topic's auto close based on last post when auto_close_topics_post_count has been reached auto_close_topics_create_linked_topic is enabled enqueues a job to create a new lin
ked topic
rspec ./spec/components/post_creator_spec.rb:464 # PostCreator new topic success tags tagging disabled doesn't create tags
rspec ./spec/components/post_creator_spec.rb:481 # PostCreator new topic success tags tagging enabled can create tags can create all tags if none exist
rspec ./spec/components/post_creator_spec.rb:486 # PostCreator new topic success tags tagging enabled can create tags creates missing tags if some exist
rspec ./spec/components/post_creator_spec.rb:500 # PostCreator new topic success tags tagging enabled cannot create tags only uses existing tags
rspec ./spec/components/post_creator_spec.rb:514 # PostCreator new topic success tags tagging enabled automatically tags first posts without regular expressions works with many tags
rspec ./spec/components/post_creator_spec.rb:521 # PostCreator new topic success tags tagging enabled automatically tags first posts without regular expressions works with overlapping words
rspec ./spec/components/post_creator_spec.rb:529 # PostCreator new topic success tags tagging enabled automatically tags first posts without regular expressions does not treat as regular expressions
rspec ./spec/components/post_creator_spec.rb:538 # PostCreator new topic success tags tagging enabled automatically tags first posts with regular expressions works
rspec ./spec/components/post_creator_spec.rb:552 # PostCreator new topic when auto-close param is given ensures the user can auto-close the topic, but ignores auto-close param silently
rspec ./spec/components/post_creator_spec.rb:564 # PostCreator whisper whispers do not mess up the public view
rspec ./spec/components/post_creator_spec.rb:642 # PostCreator silent silent do not mess up the public view
rspec ./spec/components/post_creator_spec.rb:681 # PostCreator uniqueness disabled returns true for another post with the same content
rspec ./spec/components/post_creator_spec.rb:694 # PostCreator uniqueness enabled fails for dupe post across topic
rspec ./spec/components/post_creator_spec.rb:707 # PostCreator uniqueness enabled returns blank for another post with the same content
rspec ./spec/components/post_creator_spec.rb:714 # PostCreator uniqueness enabled returns a post for admins
rspec ./spec/components/post_creator_spec.rb:721 # PostCreator uniqueness enabled returns a post for moderators
rspec ./spec/components/post_creator_spec.rb:741 # PostCreator host spam does not create the post
rspec ./spec/components/post_creator_spec.rb:749 # PostCreator host spam sends a message to moderators
rspec ./spec/components/post_creator_spec.rb:756 # PostCreator host spam does not create a reviewable post if the review_every_post setting is enabled
rspec ./spec/components/post_creator_spec.rb:770 # PostCreator existing topic ensures the user can create the post
rspec ./spec/components/post_creator_spec.rb:779 # PostCreator existing topic success create correctly
rspec ./spec/components/post_creator_spec.rb:794 # PostCreator existing topic when the user has bookmarks with auto_delete_preference on_owner_reply deletes the bookmarks, but not the ones without an auto_delete_preference
rspec ./spec/components/post_creator_spec.rb:803 # PostCreator existing topic when the user has bookmarks with auto_delete_preference on_owner_reply when there are no bookmarks left in the topic sets TopicUser.bookmarked to false
rspec ./spec/components/post_creator_spec.rb:820 # PostCreator existing topic topic stats updates topic stats
rspec ./spec/components/post_creator_spec.rb:829 # PostCreator existing topic topic stats updates topic stats even when topic fails validation
rspec ./spec/components/post_creator_spec.rb:847 # PostCreator existing topic when the topic is in slow mode fails if the user recently posted in this topic
rspec ./spec/components/post_creator_spec.rb:857 # PostCreator existing topic when the topic is in slow mode creates the topic if the user last post is older than the slow mode interval
rspec ./spec/components/post_creator_spec.rb:866 # PostCreator existing topic when the topic is in slow mode creates the topic if the user is a staff member
rspec ./spec/components/post_creator_spec.rb:883 # PostCreator closed topic responds with an error message
rspec ./spec/components/post_creator_spec.rb:895 # PostCreator missing topic responds with an error message
rspec ./spec/components/post_creator_spec.rb:906 # PostCreator cooking options passes the cooking options through correctly
rspec ./spec/components/post_creator_spec.rb:932 # PostCreator private message acts correctly
rspec ./spec/components/post_creator_spec.rb:984 # PostCreator private message does not add whisperers to allowed users of the topic
rspec ./spec/components/post_creator_spec.rb:1000 # PostCreator private message does not increase posts count for small actions
rspec ./spec/components/post_creator_spec.rb:1034 # PostCreator warnings works as expected
rspec ./spec/components/post_creator_spec.rb:1062 # PostCreator auto closing closes private messages that have more than N posts
rspec ./spec/components/post_creator_spec.rb:1084 # PostCreator auto closing closes topics that have more than N posts
rspec ./spec/components/post_creator_spec.rb:1124 # PostCreator private message to group can post to a group correctly
rspec ./spec/components/post_creator_spec.rb:1161 # PostCreator setting created_at supports Time instances
rspec ./spec/components/post_creator_spec.rb:1182 # PostCreator setting created_at supports strings
rspec ./spec/components/post_creator_spec.rb:1207 # PostCreator disable validations can save a post
rspec ./spec/components/post_creator_spec.rb:1215 # PostCreator word_count has a word count
rspec ./spec/components/post_creator_spec.rb:1229 # PostCreator embed_url creates the topic_embed record
rspec ./spec/components/post_creator_spec.rb:1250 # PostCreator read credit for creator should give credit to creator
rspec ./spec/components/post_creator_spec.rb:1262 # PostCreator suspended users does not allow suspended users to create topics
rspec ./spec/components/post_creator_spec.rb:1293 # PostCreator events fires both event when creating a topic
rspec ./spec/components/post_creator_spec.rb:1300 # PostCreator events fires only the post event when creating a post
rspec ./spec/components/post_creator_spec.rb:1311 # PostCreator staged users automatically watches all messages it participates in
rspec ./spec/components/post_creator_spec.rb:1323 # PostCreator topic tracking automatically watches topic based on preference
rspec ./spec/components/post_creator_spec.rb:1340 # PostCreator topic tracking topic notification level remains tracking based on preference
rspec ./spec/components/post_creator_spec.rb:1357 # PostCreator topic tracking topic notification level is normal based on preference
rspec ./spec/components/post_creator_spec.rb:1374 # PostCreator topic tracking user preferences for notification level when replying doesn't affect PMs
rspec ./spec/components/post_creator_spec.rb:1390 # PostCreator topic tracking sets the last_posted_at timestamp to track the last time the user posted
rspec ./spec/components/post_creator_spec.rb:1405 # PostCreator#create! should return the post if it was successfully created
rspec ./spec/components/post_creator_spec.rb:1417 # PostCreator#create! should raise an error when post fails to be created
rspec ./spec/components/post_creator_spec.rb:1422 # PostCreator#create! does not generate an alert for empty posts
rspec ./spec/components/post_creator_spec.rb:1455 # PostCreator private message to a user that has disabled private messages should not be valid
rspec ./spec/components/post_creator_spec.rb:1471 # PostCreator private message to a user that has disabled private messages should not be valid if the name is downcased
rspec ./spec/components/post_creator_spec.rb:1488 # PostCreator private message to a muted user should fail
rspec ./spec/components/post_creator_spec.rb:1509 # PostCreator private message to a muted user succeeds if the user is staff
rspec ./spec/components/post_creator_spec.rb:1532 # PostCreator private message to an ignored user when post author is ignored should fail
rspec ./spec/components/post_creator_spec.rb:1552 # PostCreator private message to an ignored user when post author is admin who is ignored succeeds if the user is staff
rspec ./spec/components/post_creator_spec.rb:1574 # PostCreator private message to user in allow list when post author is allowed should succeed
rspec ./spec/components/post_creator_spec.rb:1593 # PostCreator private message to user in allow list when personal messages are disabled should fail
rspec ./spec/components/post_creator_spec.rb:1621 # PostCreator private message to user not in allow list when post author is not allowed should fail
rspec ./spec/components/post_creator_spec.rb:1638 # PostCreator private message to user not in allow list when post author is not allowed should succeed when not enabled
rspec ./spec/components/post_creator_spec.rb:1661 # PostCreator private message when post author is admin who is not in allow list succeeds if the user is staff
rspec ./spec/components/post_creator_spec.rb:1682 # PostCreator private message to multiple users and one is not allowed when post author is not allowed should fail
rspec ./spec/components/post_creator_spec.rb:1712 # PostCreator private message recipients limit (max_allowed_message_recipients) reached for normal user fails when sending message to multiple recipients
rspec ./spec/components/post_creator_spec.rb:1724 # PostCreator private message recipients limit (max_allowed_message_recipients) reached for normal user succeeds when sending message to multiple recipients if skip_validations is true
rspec ./spec/components/post_creator_spec.rb:1741 # PostCreator private message recipients limit (max_allowed_message_recipients) reached always succeeds if the user is staff when sending message to multiple recipients
rspec ./spec/components/post_creator_spec.rb:1760 # PostCreator#create_post_notice generates post notices for new users
rspec ./spec/components/post_creator_spec.rb:1768 # PostCreator#create_post_notice generates post notices for returning users
rspec ./spec/components/post_creator_spec.rb:1779 # PostCreator#create_post_notice does not generate for non-human, staged or anonymous users
rspec ./spec/components/post_creator_spec.rb:1802 # PostCreator secure media uploads links post uploads
rspec ./spec/components/post_creator_spec.rb:1814 # PostCreator queue for review created a reviewable post after creating the post
rspec ./spec/components/post_creator_spec.rb:1823 # PostCreator queue for review does not create a reviewable post if the post is not valid2342a7903,7918
rspec ./spec/lib/backup_restore/system_interface_multisite_spec.rb:12 # BackupRestore::SystemInterface#flush_redis removes only keys from the current site in a multisite
rspec ./spec/requests/about_controller_spec.rb:33 # AboutController.index crawler view should include correct title
rspec ./spec/requests/about_controller_spec.rb:39 # AboutController.index crawler view should include correct user URLs
rspec ./spec/components/discourse_redis_spec.rb:25 # DiscourseRedis redis commands when namespace is enabled should append namespace to the keys
rspec ./spec/lib/upload_recovery_spec.rb:100 # UploadRecovery#recover recovers uploads and attachments
rspec ./spec/lib/upload_recovery_spec.rb:197 # UploadRecovery#recover image tag recovers the upload
rspec ./spec/lib/upload_recovery_spec.rb:122 # UploadRecovery#recover S3 store recovers the upload
rspec ./spec/lib/upload_recovery_spec.rb:165 # UploadRecovery#recover S3 store when the upload exists but its file is missing does not create a duplicate upload when secure uploads are enabled
rspec ./spec/lib/upload_recovery_spec.rb:146 # UploadRecovery#recover S3 store when the upload exists but its file is missing recovers the file
rspec ./spec/lib/upload_recovery_spec.rb:224 # UploadRecovery#recover image markdown recovers the upload
rspec ./spec/lib/upload_recovery_spec.rb:251 # UploadRecovery#recover bbcode recovers the upload
rspec ./spec/lib/upload_recovery_spec.rb:86 # UploadRecovery#recover for a missing attachment recovers the attachment
rspec ./spec/components/cache_spec.rb:95 # Cache can fetch keys with pattern
rspec ./spec/components/cache_spec.rb:34 # Cache can be cleared
rspec ./spec/requests/admin/site_texts_controller_spec.rb:542 # Admin::SiteTextsController when logged in as admin reseeding #reseed reseeds categories and topics
rspec ./spec/models/report_spec.rb:97 # Report counting topics counts the correct records
rspec ./spec/models/theme_spec.rb:584 # Theme convert_settings can migrate a list field to a string field with json schema
rspec ./spec/models/theme_spec.rb:605 # Theme convert_settings does not update setting if data does not validate against json schema
rspec ./spec/lib/seed_data/categories_spec.rb:148 # SeedData::Categories#update works when the category name is already used by another category
rspec ./spec/lib/seed_data/categories_spec.rb:136 # SeedData::Categories#update skips category when `skip_changed` is true and description was changed
rspec ./spec/lib/seed_data/categories_spec.rb:124 # SeedData::Categories#update updates an existing category
rspec ./spec/lib/backup_restore/backup_file_handler_spec.rb:48 # BackupRestore::BackupFileHandler allows overriding the backup store
rspec ./spec/lib/backup_restore/backup_file_handler_spec.rb:26 # BackupRestore::BackupFileHandler works with backup file which uses wrong upload path
rspec ./spec/lib/backup_restore/system_interface_spec.rb:177 # BackupRestore::SystemInterface#flush_redis Sidekiq doesn't unpause Sidekiq
rspec ./spec/requests/static_controller_spec.rb:25 # StaticController#favicon local store returns the default favicon if favicon has not been configured
rspec ./spec/requests/static_controller_spec.rb:33 # StaticController#favicon local store returns the configured favicon
rspec ./spec/requests/static_controller_spec.rb:58 # StaticController#favicon external store can proxy a favicon correctly
rspec ./spec/components/topic_view_spec.rb:956 # TopicView#reviewable_counts include posts queued for other reasons
rspec ./spec/components/topic_view_spec.rb:937 # TopicView#reviewable_counts exclude posts queued because the category needs approval
rspec ./spec/services/user_authenticator_spec.rb:47 # UserAuthenticator#finish confirms email and adds the user to appropriate groups based on email
rspec ./spec/services/user_authenticator_spec.rb:58 # UserAuthenticator#finish doesn't confirm email if email is invalid
rspec ./spec/services/user_authenticator_spec.rb:68 # UserAuthenticator#finish doesn't confirm email if it was changed
rspec ./spec/components/wizard/step_updater_spec.rb:22 # Wizard::StepUpdater locale updates the locale and requires refresh when it does change
rspec ./spec/models/post_spec.rb:65 # Post is expected to validate that :raw cannot be empty/falsy
rspec ./spec/models/post_spec.rb:69 # Post is expected not to allow :raw to be ‹"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx...›
rspec ./spec/models/post_spec.rb:70 # Post is expected not to allow :raw to be ‹"     x"›
rspec ./spec/models/post_spec.rb:68 # Post is expected not to allow :raw to be ‹"x"›
rspec ./spec/models/post_spec.rb:644 # Post validation create blank posts as invalid
rspec ./spec/lib/backup_restore/local_backup_store_spec.rb[1:1:3:7:3] # BackupRestore::LocalBackupStore behaves like backup store with backup files #download_file works with multisite
rspec ./spec/lib/backup_restore/local_backup_store_spec.rb[1:1:3:4:3] # BackupRestore::LocalBackupStore behaves like backup store with backup files #delete_old works with multisite
rspec ./spec/lib/backup_restore/local_backup_store_spec.rb[1:1:3:4:2] # BackupRestore::LocalBackupStore behaves like backup store with backup files #delete_old deletes files starting by the oldest
rspec ./spec/lib/backup_restore/local_backup_store_spec.rb[1:1:3:6:1] # BackupRestore::LocalBackupStore behaves like backup store with backup files #delete_file deletes file when the file exists
rspec ./spec/lib/backup_restore/local_backup_store_spec.rb[1:1:3:6:3] # BackupRestore::LocalBackupStore behaves like backup store with backup files #delete_file works with multisite
rspec ./spec/lib/backup_restore/local_backup_store_spec.rb[1:1:3:3:1] # BackupRestore::LocalBackupStore behaves like backup store with backup files #reset_cache resets the storage stats report
rspec ./spec/lib/backup_restore/local_backup_store_spec.rb[1:1:3:2:2] # BackupRestore::LocalBackupStore behaves like backup store with backup files #latest_file returns nil when there are no files
rspec ./spec/jobs/vacate_legacy_prefix_backups_spec.rb:24 # Jobs::VacateLegacyPrefixBackups copies the backups from legacy path to new path
rspec ./spec/components/topic_retriever_spec.rb:11 # TopicRetriever can initialize without optional parameters
rspec ./spec/requests/uploads_controller_spec.rb:819 # UploadsController#create_multipart when the store is external returns 422 when the file is an attachment and it's too big
rspec ./spec/requests/uploads_controller_spec.rb:807 # UploadsController#create_multipart when the store is external returns 422 when the create request errors
rspec ./spec/requests/uploads_controller_spec.rb:876 # UploadsController#create_multipart when the store is external includes accepted metadata when calling the store to create_multipart, but only allowed keys
rspec ./spec/requests/uploads_controller_spec.rb:847 # UploadsController#create_multipart when the store is external creates a multipart upload and creates an external upload stub that is marked as multipart
rspec ./spec/requests/uploads_controller_spec.rb:744 # UploadsController#generate_presigned_put when the store is external includes accepted metadata in the presigned url when provided
rspec ./spec/components/email/receiver_spec.rb:1353 # Email::Receiver new topic in a category creates hidden topic for X-Spam-Flag
rspec ./spec/components/email/receiver_spec.rb:1395 # Email::Receiver new topic in a category works when approving is enabled
rspec ./spec/components/email/receiver_spec.rb:1377 # Email::Receiver new topic in a category creates hidden topic for failed Authentication-Results header
rspec ./spec/components/email/receiver_spec.rb:1361 # Email::Receiver new topic in a category creates hidden topic for X-Spam-Status
rspec ./spec/components/email/receiver_spec.rb:1369 # Email::Receiver new topic in a category creates hidden topic for X-SES-Spam-Verdict
rspec ./spec/integration/watched_words_spec.rb:101 # WatchedWord require_approval looks at title too
rspec ./spec/integration/watched_words_spec.rb:94 # WatchedWord require_approval should queue the post for approval
rspec ./spec/lib/seed_data/topics_spec.rb:84 # SeedData::Topics#update updates an existing first reply when `static_first_reply` is true
rspec ./spec/lib/seed_data/topics_spec.rb:96 # SeedData::Topics#update does not update a change topic and `skip_changed` is true
rspec ./spec/lib/seed_data/topics_spec.rb:70 # SeedData::Topics#update updates the changed topic
rspec ./spec/requests/admin/backups_controller_spec.rb:132 # Admin::BackupsController#destroy removes the backup if found
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:2:1] # BackupRestore::S3BackupStore behaves like remote backup store is a remote store
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:2:2:2:2] # BackupRestore::S3BackupStore behaves like remote backup store with backups #generate_upload_url raises an exception when a file with same filename exists
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:2:2:2:3] # BackupRestore::S3BackupStore behaves like remote backup store with backups #generate_upload_url works with multisite
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:2:2:2:1] # BackupRestore::S3BackupStore behaves like remote backup store with backups #generate_upload_url generates upload URL
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:2:2:1:3] # BackupRestore::S3BackupStore behaves like remote backup store with backups #upload_file raises an exception when a file with same filename exists
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:2:2:1:2] # BackupRestore::S3BackupStore behaves like remote backup store with backups #upload_file works with multisite
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:2:2:1:1] # BackupRestore::S3BackupStore behaves like remote backup store with backups #upload_file uploads file into store
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:1] # BackupRestore::S3BackupStore behaves like backup store creates the correct backup store
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:8:1] # BackupRestore::S3BackupStore behaves like backup store with backup files #stats returns the correct stats
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:1:3] # BackupRestore::S3BackupStore behaves like backup store with backup files #files works with multisite
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:1:1] # BackupRestore::S3BackupStore behaves like backup store with backup files #files sorts files by last modified date in descending order
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:1:2] # BackupRestore::S3BackupStore behaves like backup store with backup files #files returns only *.gz and *.tgz files
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:7:3] # BackupRestore::S3BackupStore behaves like backup store with backup files #download_file works with multisite
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:7:2] # BackupRestore::S3BackupStore behaves like backup store with backup files #download_file raises an exception when the download fails
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:7:1] # BackupRestore::S3BackupStore behaves like backup store with backup files #download_file downloads file to the destination
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:5:4] # BackupRestore::S3BackupStore behaves like backup store with backup files #file works with multisite
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:5:2] # BackupRestore::S3BackupStore behaves like backup store with backup files #file returns nil when the file doesn't exist
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:5:3] # BackupRestore::S3BackupStore behaves like backup store with backup files #file includes the file's source location if it is requested
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:5:1] # BackupRestore::S3BackupStore behaves like backup store with backup files #file returns information about the file when the file exists
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:4:2] # BackupRestore::S3BackupStore behaves like backup store with backup files #delete_old deletes files starting by the oldest
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:4:1] # BackupRestore::S3BackupStore behaves like backup store with backup files #delete_old does nothing if the number of files is <= maximum_backups
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:4:3] # BackupRestore::S3BackupStore behaves like backup store with backup files #delete_old works with multisite
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:6:1] # BackupRestore::S3BackupStore behaves like backup store with backup files #delete_file deletes file when the file exists
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:6:2] # BackupRestore::S3BackupStore behaves like backup store with backup files #delete_file does nothing when the file doesn't exist
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:6:3] # BackupRestore::S3BackupStore behaves like backup store with backup files #delete_file works with multisite
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:3:1] # BackupRestore::S3BackupStore behaves like backup store with backup files #reset_cache resets the storage stats report
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:2:3] # BackupRestore::S3BackupStore behaves like backup store with backup files #latest_file works with multisite
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:2:1] # BackupRestore::S3BackupStore behaves like backup store with backup files #latest_file returns the most recent backup file
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:3:2:2] # BackupRestore::S3BackupStore behaves like backup store with backup files #latest_file returns nil when there are no files
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:2:2:1] # BackupRestore::S3BackupStore behaves like backup store without backup files #latest_file returns nil when there are no files
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:2:1:1] # BackupRestore::S3BackupStore behaves like backup store without backup files #files returns an empty array when there are no files
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb[1:1:2:3:1] # BackupRestore::S3BackupStore behaves like backup store without backup files #stats works when there are no files
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb:86 # BackupRestore::S3BackupStore S3 specific behavior #delete_old doesn't delete files when cleanup is disabled
rspec ./spec/lib/backup_restore/s3_backup_store_spec.rb:95 # BackupRestore::S3BackupStore S3 specific behavior #stats returns nil for 'free_bytes'
rspec ./spec/tasks/posts_spec.rb:49 # Post rake tasks rebake_match rebakes matched posts
rspec ./spec/requests/posts_controller_spec.rb[1:12:1] # PostsController#post_type raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:11:1] # PostsController#wiki raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:7:1] # PostsController#destroy_many raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:8:1] # PostsController#recover raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:16:1] # PostsController#revert raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:13:1] # PostsController#rebake raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:18:1] # PostsController#flagged_posts raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:26:1] # PostsController#raw_email raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:14:1] # PostsController#create raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb:913 # PostsController#create when logged in silences correctly based on silence watched words
rspec ./spec/requests/posts_controller_spec.rb:893 # PostsController#create when logged in silences correctly based on auto_silence_first_post_regex
rspec ./spec/requests/posts_controller_spec.rb:807 # PostsController#create when logged in fast typing queues the post if min_first_post_typing_time is not met
rspec ./spec/requests/posts_controller_spec.rb[1:19:1] # PostsController#deleted_posts raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:6:1] # PostsController#destroy raises an exception when not logged in
rspec ./spec/requests/posts_controller_spec.rb[1:9:1] # PostsController#update raises an exception when not logged in
rspec ./spec/components/new_post_manager_spec.rb:581 # NewPostManager when posting in the category requires approval when new posts require approval enqueues new posts
rspec ./spec/components/new_post_manager_spec.rb:464 # NewPostManager when posting in the category requires approval when new topics require approval enqueues new topics
rspec ./spec/components/new_post_manager_spec.rb:536 # NewPostManager when posting in the category requires approval when new topics require approval when the category has tagging rules when there is a minimum number of tags required from a certain tag group for the categ
ory errors when there are no tags from the group provided
rspec ./spec/components/new_post_manager_spec.rb:556 # NewPostManager when posting in the category requires approval when new topics require approval when the category has tagging rules when there is a minimum number of tags required from a certain tag group for the categ
ory enqueues the topic if there are tags provided
rspec ./spec/components/new_post_manager_spec.rb:499 # NewPostManager when posting in the category requires approval when new topics require approval when the category has tagging rules when there is a minimum number of tags required for the category errors when there are
 no tags provided
rspec ./spec/components/new_post_manager_spec.rb:512 # NewPostManager when posting in the category requires approval when new topics require approval when the category has tagging rules when there is a minimum number of tags required for the category enqueues the topic if
rspec ./spec/components/new_post_manager_spec.rb:105 # NewPostManager default handler with a high approval post count and TL0 will return an enqueue result
rspec ./spec/components/new_post_manager_spec.rb:173 # NewPostManager default handler with uncategorized disabled, and approval will return an enqueue result
rspec ./spec/components/new_post_manager_spec.rb:138 # NewPostManager default handler with a high approval post count and secure category does not create topic
rspec ./spec/components/new_post_manager_spec.rb:79 # NewPostManager default handler basic post/topic count restrictions works with a correct `user_stat.post_count`
rspec ./spec/components/new_post_manager_spec.rb:89 # NewPostManager default handler basic post/topic count restrictions works with a correct `user_stat.topic_count`
rspec ./spec/components/new_post_manager_spec.rb:193 # NewPostManager default handler with staged moderation setting enabled will return an enqueue result
rspec ./spec/components/new_post_manager_spec.rb:259 # NewPostManager default handler with media queues the post for review because if it contains embedded media.
rspec ./spec/components/new_post_manager_spec.rb:159 # NewPostManager default handler with a high trust level setting will return an enqueue result
rspec ./spec/components/new_post_manager_spec.rb:118 # NewPostManager default handler with a high approval post count and TL1 will return an enqueue result
rspec ./spec/components/new_post_manager_spec.rb:227 # NewPostManager default handler with a fast typer runs the watched words check before checking if the user is a fast typer
rspec ./spec/components/new_post_manager_spec.rb:218 # NewPostManager default handler with a fast typer adds the silence reason in the system locale
rspec ./spec/components/new_post_manager_spec.rb:286 # NewPostManager new topic handler with a high trust level setting for new topics will return an enqueue result
rspec ./spec/components/new_post_manager_spec.rb:685 # NewPostManager via email with an authentication results failure doesn't silence users
rspec ./spec/components/new_post_manager_spec.rb:700 # NewPostManager via email with an authentication results failure still enqueues exempt users
rspec ./spec/components/new_post_manager_spec.rb:650 # NewPostManager via email with a spam failure silences users if its their first post
rspec ./spec/components/new_post_manager_spec.rb:633 # NewPostManager via email will store via_email and raw_email in the enqueued post
rspec ./spec/components/validators/post_validator_spec.rb[1:10:1] # PostValidator staged user skips most validations
rspec ./spec/components/validators/post_validator_spec.rb[1:9:1] # PostValidator admin editing a static page skips most validations
rspec ./spec/components/validators/post_validator_spec.rb:229 # PostValidator invalid post should be invalid
rspec ./spec/components/redis_store_spec.rb:46 # Redis Store can be cleared without clearing our cache
rspec ./spec/requests/topics_controller_spec.rb:3363 # TopicsController#reset_new specific topics updates the `new_since` date
rspec ./spec/requests/topics_controller_spec.rb:3388 # TopicsController#reset_new specific topics when tracked param is true does not update user_stat.new_since and does not dismiss untracked topics
rspec ./spec/requests/topics_controller_spec.rb:3401 # TopicsController#reset_new specific topics when tracked param is true creates topic user records for each unread topic
GitHub
The title of this pull request changed from “Fix: Support Ruby 3 keyword arguments” to "FIX: Support Ruby 3 keyword arguments
Thank you very much for fixing this. It looks excellent.
