FIX: Swap fancy_title with decrypted title (#151)
The topic title from a topic page used to be replaced with the decrypted title after it was rendered. This meant that the placeholder title element was replaced with another element that contained the decrypted topic title.
This was a problem because it changed the DOM structure and Ember stored references to elements it rendered, but were replaced. More specifically, it called removeChild to remove an element that did not exist anymore, which threw an exception.
This solution gets the model object from the topic controller and replaces its fancy_title with the decrypted title.
diff --git a/assets/javascripts/discourse/initializers/decrypt-topics.js b/assets/javascripts/discourse/initializers/decrypt-topics.js
index dcc46e8..fce2ad7 100644
--- a/assets/javascripts/discourse/initializers/decrypt-topics.js
+++ b/assets/javascripts/discourse/initializers/decrypt-topics.js
@@ -13,21 +13,20 @@ import {
   syncGetTopicTitle,
   waitForPendingTitles,
 } from "discourse/plugins/discourse-encrypt/lib/discourse";
-import I18n from "I18n";
- * Decrypts all elements described by a selector.
+ * Decrypts elements that contain topic titles
  * @param {String} containerSelector Item list (container) selector
- * @param {String} elementSelector   Encrypted element selector
- *                                   If not present, the container element is
- *                                   used
- * @param {{ addIcon: Boolean,
- *           replaceIcon: Boolean }} opts
+ * @param {String} elementSelector   Encrypted title element selector
+ *                                   If not present, the container is used
+ * @param {Boolean} addIcon          Adds "user-secret" icon before title
-function decryptElements(containerSelector, elementSelector, opts) {
-  opts = opts || {};
+function decryptTopicTitles(
+  containerSelector,
+  elementSelector,
+  addIcon = false
   document.querySelectorAll(containerSelector).forEach((element) => {
     const titleElement = elementSelector
       ? element.querySelector(elementSelector)
@@ -44,20 +43,13 @@ function decryptElements(containerSelector, elementSelector, opts) {
     getTopicTitle(topicId)
       .then((title) => {
         title = emojiUnescape(escapeExpression(title));
-        const icon = iconHTML("user-secret", {
-          title: "encrypt.encrypted_icon_title",
-          class: "private-message-glyph",
-        if (opts.replaceIcon) {
-          const iconElement = element.querySelector(
-            ".private-message-glyph-wrapper"
-          if (iconElement) {
-            iconElement.innerHTML = icon;
-            titleElement.innerHTML = title;
-        } else if (opts.addIcon) {
+        if (addIcon) {
+          const icon = iconHTML("user-secret", {
+            title: "encrypt.encrypted_icon_title",
+            class: "private-message-glyph",
           titleElement.innerHTML = icon + " " + title;
         } else {
@@ -65,7 +57,7 @@ function decryptElements(containerSelector, elementSelector, opts) {
       .catch(() => {});
-    // Hide quick-edit button for the time being
+    // HACK: Hide quick-edit button for the time being
     const quickEditBtn = element.querySelector(".edit-topic");
     if (quickEditBtn) {
       quickEditBtn.style.display = "none";
@@ -73,6 +65,38 @@ function decryptElements(containerSelector, elementSelector, opts) {
+ * Replaces PM icon with "user-secret" icon
+ * @param {String} containerSelector Item list (container) selector
+ * @param {Boolean} iconSelector     Icon container selector
+function replaceIcons(containerSelector, elementSelector, iconSelector) {
+  document.querySelectorAll(containerSelector).forEach((element) => {
+    const titleElement = elementSelector
+      ? element.querySelector(elementSelector)
+      : element;
+    if (!titleElement) {
+      return;
+    const topicId = element.dataset.topicId || titleElement.dataset.topicId;
+    if (!topicId || !hasTopicTitle(topicId)) {
+      return;
+    const iconElement = element.querySelector(iconSelector);
+    if (iconElement) {
+      iconElement.innerHTML = iconHTML("user-secret", {
 export default {
   container: null,
@@ -83,20 +107,19 @@ export default {
       return;
-    // Save a reference to container to be used by `decryptDocTitle`.
+    // Save a reference to container to be used by `decryptTopicPage`
     this.container = container;
     const appEvents = container.lookup("service:app-events");
-    appEvents.on("encrypt:status-changed", this, this.decryptTitles);
-    appEvents.on("page:changed", this, this.decryptDocTitle);
+    appEvents.on("encrypt:status-changed", this, this.decryptTopicTitles);
+    appEvents.on("page:changed", this, this.decryptTopicPage);
-    // Try to decrypt new titles that may appear after rendering a component.
+    // Try to decrypt new titles that may appear after rendering a component
     const self = this;
     Component.reopen({
       didRender() {
         scheduleOnce("afterRender", self, () => {
-          discourseDebounce(self, self.decryptTitles, 500);
+          discourseDebounce(self, self.decryptTopicTitles, 500);
         return this._super(...arguments);
@@ -161,41 +184,73 @@ export default {
           helper.widget.state.userVisible ||
           helper.widget.state.searchVisible
-  decryptTitles() {
-    decryptElements("a.raw-topic-link", null, { addIcon: true });
-    decryptElements("a.topic-link", "span");
-    decryptElements("a.topic-link", null, { addIcon: true });
+  decryptTopicTitles() {
+    // Title in miscellaneous
+    decryptTopicTitles("a.raw-topic-link", null, true);
+    decryptTopicTitles("a.topic-link", "span");
+    decryptTopicTitles("a.topic-link", null, true);
     // Title in site header
-    decryptElements("h1.header-title", ".topic-link", { replaceIcon: true });
-    // Title in topic header
-    decryptElements("h1", ".fancy-title", { replaceIcon: true });
+    decryptTopicTitles("h1.header-title", ".topic-link");
     // Title in topic lists
-    decryptElements(".topic-list-item, .latest-topic-list-item", ".title", {
-      addIcon: true,
+      ".topic-list-item, .latest-topic-list-item",
+      ".title",
+      true
+    // Replace PM icons
+    replaceIcons("h1", null, ".private-message-glyph-wrapper");
+    replaceIcons("h1", ".topic-link", ".private-message-glyph-wrapper");
+    // Decrypt topic controller
+    // This is necessary because sometimes the model is loaded after
+    // page:changed event was triggered.
+    if (
+      !this.container ||
+      this.container.isDestroyed ||
+      this.container.isDestroying
+      return;
+    const router = this.container.lookup("router:main");
+    this.decryptTopicPage({ currentRouteName: router.currentRouteName });
-  decryptDocTitle(data) {
+  decryptTopicPage(data) {
     if (!data.currentRouteName.startsWith("topic.")) {
       return;
-    const topicId = this.container.lookup("controller:topic").get("model.id");
+    if (
+      return;
+    const topicController = this.container.lookup("controller:topic");
+    const topicId = topicController.get("model.id");
     getTopicTitle(topicId).then((topicTitle) => {
+      // Update fancy title stored in model
+      topicController.model.set("fancy_title", topicTitle);
+      // Update document title
       const documentTitle = this.container.lookup("service:document-title");
       documentTitle.setTitle(
         documentTitle
           .getTitle()
-          .replace(I18n.t("encrypt.encrypted_title"), topicTitle)
+          .replace(topicController.model.title, topicTitle)
GitHub sha: 4e56a2445e2964266c1ac156a63721594b211082
This commit appears in #151 which was approved by eviltrout. It was merged by udan11.
