FIX: Switching composer action shouldn't trigger abandon popup (#7261)
FIX: Switching composer action shouldn’t trigger abandon popup (#7261)
diff --git a/app/assets/javascripts/select-kit/components/composer-actions.js.es6 b/app/assets/javascripts/select-kit/components/composer-actions.js.es6
index e78aa7f..1d62264 100644
--- a/app/assets/javascripts/select-kit/components/composer-actions.js.es6
+++ b/app/assets/javascripts/select-kit/components/composer-actions.js.es6
@@ -230,12 +230,14 @@ export default DropdownSelectBoxComponent.extend({
   replyToTopicSelected(options) {
     options.action = REPLY;
     options.topic = _topicSnapshot;
+    options.skipDraftCheck = true;
     this._openComposer(options);
   replyToPostSelected(options) {
     options.post = _postSnapshot;
diff --git a/test/javascripts/acceptance/composer-test.js.es6 b/test/javascripts/acceptance/composer-test.js.es6
index fcbff94..73a9057 100644
--- a/test/javascripts/acceptance/composer-test.js.es6
+++ b/test/javascripts/acceptance/composer-test.js.es6
@@ -600,6 +600,47 @@ QUnit.test("Checks for existing draft", async assert => {
   toggleCheckDraftPopup(false);
+QUnit.test("Can switch states without abandon popup", async assert => {
+  const composerActions = selectKit(".composer-actions");
+  toggleCheckDraftPopup(true);
+  await visit("/t/internationalization-localization/280");
+  const longText = "a".repeat(256);
+  await click(".btn-primary.create.btn");
+  await fillIn(".d-editor-input", longText);
+  // prettier-ignore
+  server.get("/draft.json", () => { // eslint-disable-line no-undef
+    return [ 200, { "Content-Type": "application/json" }, {
+      draft: "{\"reply\":\"This is a draft of the first post\",\"action\":\"reply\",\"categoryId\":1,\"archetypeId\":\"regular\",\"metaData\":null,\"composerTime\":2863,\"typingTime\":200}",
+      draft_sequence: 42
+  await click("article#post_3 button.reply");
+  await composerActions.expand();
+  await composerActions.selectRowByValue("reply_to_topic");
+  assert.equal(find(".modal-body").text(), "", "abandon popup shouldn't come");
+  assert.equal(
+    find(".d-editor-input").val(),
+    longText,
+    "entered text should still be there"
+  assert.ok(
+    find('.action-title a[href="/t/internationalization-localization/280"]'),
+    "mode should have changed"
+  toggleCheckDraftPopup(false);
 QUnit.test("Loading draft also replaces the recipients", async assert => {
GitHub sha: 1b0267b0
