FIX: symbols and strings should be treated similarly while saving custom fields (PR #10486)
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/inconsistent-behaviour-in-userupdater-class/161360/6
  • I see some checks are failing but I haven’t touched the frontend code I promise :wink:
Hey @fzngagan this looks good but we will need a test to confirm the functionality and to avoid regressions.
https://meta.discourse.org/t/custom-field-casting-affected-by-recent-update/122746/6
@eviltrout I uncovered an issue and accounted for all different cases.
Small typo
      it 'allows using string and symbol indices interchangeably' do
         # Update via string index again
@ZogStriP thanks for pointing out the typos. Accepted both the changes :+1:
Thank you!
@eviltrout I think you didn’t squash merge as always but that’s fine I guess? :slight_smile:
regression :frowning: https://meta.discourse.org/t/custom-fields-called-simultaneous-cause-value-to-turn-into-array/162034/2
@sbrighiu I don’t see how this is a regression?
Hi @eviltrout,
It seems to be related from what @fzngagan is saying.
All I know is I call the same endpoint 3-8 at the same time and when I check the custom fields values, they are Arrays instead of Strings.
