FIX: Take action should agree with all pending flags
diff --git a/lib/post_action_creator.rb b/lib/post_action_creator.rb
index ce582cc..0ee475c 100644
--- a/lib/post_action_creator.rb
+++ b/lib/post_action_creator.rb
@@ -89,6 +89,12 @@ class PostActionCreator
         PostActionNotifier.post_action_created(post_action)
         notify_subscribers
+        # agree with other flags
+        if @take_action && reviewable = @post.reviewable_flag
+          result.reviewable.perform(@created_by, :agree_and_keep)
+          post_action.try(:update_counters)
+        end
         result.success = true
         result.post_action = post_action
@@ -211,12 +217,6 @@ private
     GivenDailyLike.increment_for(@created_by.id) if @post_action_type_id == PostActionType.types[:like]
-    # agree with other flags
-    if @take_action && reviewable = @post.reviewable_flag
-      reviewable.perform(@created_by, :agree_and_keep)
-      post_action.try(:update_counters)
-    end
     post_action
   rescue ActiveRecord::RecordNotUnique
     # can happen despite being .create
diff --git a/spec/components/post_action_creator_spec.rb b/spec/components/post_action_creator_spec.rb
index 56fc67b..e59f85d 100644
--- a/spec/components/post_action_creator_spec.rb
+++ b/spec/components/post_action_creator_spec.rb
@@ -101,4 +101,23 @@ describe PostActionCreator do
+  context "take_action" do
+    before do
+      PostActionCreator.create(Fabricate(:user), post, :inappropriate)
+    end
+    it "will agree with the old reviewable" do
+      reviewable = PostActionCreator.new(
+        Fabricate(:moderator),
+        post,
+        PostActionType.types[:spam],
+        take_action: true
+      ).perform.reviewable
+      scores = reviewable.reviewable_scores
+      expect(scores[0]).to be_agreed
+      expect(scores[1]).to be_agreed
+      expect(reviewable.reload).to be_approved
+    end
+  end
GitHub sha: df1ab925
