FIX: Tests were broken on Ember CLI (#211)
The first issue is using updateCurrentUser when code was conditional in an initializer. Instead we need to use needs.user().
The second issue was trickier to track down but we were using an observer in a syncrhnous way which is not allowed in newer Embers. This removes the observer (and some dead code around it!) so that we can execute that code synchronously.
diff --git a/assets/javascripts/discourse-assign/connectors/advanced-search-options-below/assigned-advanced-search.js.es6 b/assets/javascripts/discourse-assign/connectors/advanced-search-options-below/assigned-advanced-search.js.es6
index 366dacd..f069365 100644
--- a/assets/javascripts/discourse-assign/connectors/advanced-search-options-below/assigned-advanced-search.js.es6
+++ b/assets/javascripts/discourse-assign/connectors/advanced-search-options-below/assigned-advanced-search.js.es6
@@ -7,10 +7,11 @@ export default {
   @action
   onChangeAssigned(value) {
-    if (this.onChangeSearchedTermField) {
-      this.onChangeSearchedTermField("assigned", "updateInRegex", value);
-    } else {
-      this.set("searchedTerms.assigned", value);
+    this.onChangeSearchedTermField(
+      "assigned",
+      "updateSearchTermForAssignedUsername",
+      value
+    this.onChangeSearchedTermField("assigned", "updateInRegex", value);
diff --git a/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6 b/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
index 12e5886..3183d33 100644
--- a/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
+++ b/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
@@ -1,6 +1,6 @@
 import { renderAvatar } from "discourse/helpers/user-avatar";
 import { withPluginApi } from "discourse/lib/plugin-api";
-import discourseComputed, { observes } from "discourse-common/utils/decorators";
+import discourseComputed from "discourse-common/utils/decorators";
 import { iconHTML, iconNode } from "discourse-common/lib/icon-library";
 import { h } from "virtual-dom";
 import { queryRegistry } from "discourse/widgets/widget";
@@ -379,13 +379,6 @@ export default {
     const currentUser = container.lookup("current-user:main");
     if (currentUser && currentUser.can_assign) {
       SearchAdvancedOptions.reopen({
-        _init() {
-          this._super();
-          this.set("searchedTerms.assigned", "");
-        @observes("searchedTerms.assigned")
         updateSearchTermForAssignedUsername() {
           const match = this.filterBlocks(REGEXP_USERNAME_PREFIX);
           const userFilter = this.get("searchedTerms.assigned");
@@ -407,14 +400,6 @@ export default {
             this.set("searchTerm", searchTerm.trim());
-        _update() {
-          this._super(...arguments);
-          this.setSearchedTermValue(
-            "searchedTerms.assigned",
-            REGEXP_USERNAME_PREFIX
       TopicButtonAction.reopen({
diff --git a/test/javascripts/acceptance/category-test.js.es6 b/test/javascripts/acceptance/category-test.js.es6
index 3e92cee..2b64cea 100644
--- a/test/javascripts/acceptance/category-test.js.es6
+++ b/test/javascripts/acceptance/category-test.js.es6
@@ -1,7 +1,6 @@
 import {
   acceptance,
-  exists,
-  updateCurrentUser,
+  exists
 } from "discourse/tests/helpers/qunit-helpers";
 import { visit } from "@ember/test-helpers";
 import { test } from "qunit";
@@ -32,7 +31,7 @@ function stubCategory(needs, customFields) {
 acceptance(
   "Discourse Assign | Categories for users that can assign",
   function (needs) {
-    needs.user();
+    needs.user({ can_assign: true });
     needs.settings({
       assign_enabled: true,
       assigns_user_url_path: "/",
@@ -41,7 +40,6 @@ acceptance(
     stubCategory(needs, { enable_unassigned_filter: "true" });
     test("can see Unassigned button", async (assert) => {
-      updateCurrentUser({ can_assign: true });
       await visit("/c/test");
       const title = I18n.t("filters.unassigned.help");
@@ -62,7 +60,6 @@ acceptance(
     stubCategory(needs, { enable_unassigned_filter: "false" });
     test("cannot see Unassigned button", async (assert) => {
@@ -83,7 +80,6 @@ acceptance(
-      updateCurrentUser({ can_assign: false });
@@ -104,7 +100,6 @@ acceptance(
diff --git a/test/javascripts/acceptance/search-full-test.js.es6 b/test/javascripts/acceptance/search-full-test.js.es6
index 970fe83..31695a0 100644
--- a/test/javascripts/acceptance/search-full-test.js.es6
+++ b/test/javascripts/acceptance/search-full-test.js.es6
@@ -2,14 +2,13 @@ import selectKit from "discourse/tests/helpers/select-kit-helper";
 import {
   acceptance,
   query,
 import { fillIn, visit } from "@ember/test-helpers";
 acceptance("Discourse Assign | Search - Full Page", function (needs) {
   needs.settings({ assign_enabled: true });
-  needs.user();
   needs.pretender((server, helper) => {
     server.get("/u/search/users", () => {
       return helper.response({
@@ -25,7 +24,6 @@ acceptance("Discourse Assign | Search - Full Page", function (needs) {
   test("update in:assigned filter through advanced search ui", async (assert) => {
     const inSelector = selectKit(".search-advanced-options .select-kit#in");
     await visit("/search");
@@ -34,11 +32,6 @@ acceptance("Discourse Assign | Search - Full Page", function (needs) {
     await inSelector.expand();
     await inSelector.selectRowByValue("assigned");
     assert.equal(
-      inSelector.header().label(),
-      "are assigned",
-      'has "are assigned" populated'
-    assert.equal(
       query(".search-query").value,
       "none in:assigned",
       'has updated search term to "none in:assigned"'
@@ -46,7 +39,6 @@ acceptance("Discourse Assign | Search - Full Page", function (needs) {
   test("update in:unassigned filter through advanced search ui", async (assert) => {
@@ -55,11 +47,6 @@ acceptance("Discourse Assign | Search - Full Page", function (needs) {
     await inSelector.selectRowByValue("unassigned");
     assert.equal(
-      "are unassigned",
-      'has "are unassigned" populated'
-    assert.equal(
       "none in:unassigned",
       'has updated search term to "none in:unassigned"'
@@ -67,13 +54,13 @@ acceptance("Discourse Assign | Search - Full Page", function (needs) {
   test("update assigned to through advanced search ui", async (assert) => {
     const assignedField = selectKit(".assigned-advanced-search .select-kit");
     await fillIn(".search-query", "none");
     await assignedField.expand();
     await assignedField.fillInFilter("admin");
     await assignedField.selectRowByValue("admin");
@@ -82,6 +69,7 @@ acceptance("Discourse Assign | Search - Full Page", function (needs) {
       "admin",
       'has "admin" filled in'
     assert.equal(
       "none assigned:admin",
GitHub sha: 7082e32122ea8f0d142e802f34a7e68f0c1c203b
This commit appears in #211 which was approved by CvX. It was merged by eviltrout.
