FIX: the ability to remove the vote (PR #55)
Problem was that we are adding hidden class to popup and jQuery toggle() function is not handling that properly. Therefore I decided to use toggleClass in that case and it works pretty well.
The bug was mentioned here - https://meta.discourse.org/t/voting-plugin/157676/8
YFqWdYFAQd
GitHub
