Fix the build take 2.
diff --git a/lib/tasks/smoke_test.rake b/lib/tasks/smoke_test.rake
index c547f3c..d8eefa9 100644
--- a/lib/tasks/smoke_test.rake
+++ b/lib/tasks/smoke_test.rake
@@ -41,7 +41,7 @@ task "smoke:test" do
     raise "TRIVIAL GET FAILED WITH #{response.code}"
-  results = ""
+  results = +""
   IO.popen("node #{Rails.root}/test/smoke_test.js #{url}").each do |line|
     puts line
diff --git a/plugins/discourse-narrative-bot/lib/discourse_narrative_bot/dice.rb b/plugins/discourse-narrative-bot/lib/discourse_narrative_bot/dice.rb
index 18d4fd2..43af00e 100644
--- a/plugins/discourse-narrative-bot/lib/discourse_narrative_bot/dice.rb
+++ b/plugins/discourse-narrative-bot/lib/discourse_narrative_bot/dice.rb
@@ -10,7 +10,7 @@ module DiscourseNarrativeBot
         return I18n.t('discourse_narrative_bot.dice.invalid')
-      output = ''
+      output = +''
       if num_of_dice > MAXIMUM_NUM_OF_DICE
         output << I18n.t('discourse_narrative_bot.dice.not_enough_dice',
GitHub sha: c00dab89
