Fix the build. Updated spec to comply with the new discourse-assign rules
diff --git a/spec/integration/discourse_prometheus_alert_receiver/receiver_controller_spec.rb b/spec/integration/discourse_prometheus_alert_receiver/receiver_controller_spec.rb
index f0f9d27..20cf213 100644
--- a/spec/integration/discourse_prometheus_alert_receiver/receiver_controller_spec.rb
+++ b/spec/integration/discourse_prometheus_alert_receiver/receiver_controller_spec.rb
@@ -10,6 +10,10 @@ RSpec.describe DiscoursePrometheusAlertReceiver::ReceiverController do
   let(:parsed_response_body) { JSON.parse(response_body) }
   let(:plugin_name) { DiscoursePrometheusAlertReceiver::PLUGIN_NAME }
+  before do
+    SiteSetting.assign_allowed_on_groups += "|#{assignee_group.id}"
+  end
   let(:custom_field_key) do
     DiscoursePrometheusAlertReceiver::ALERT_HISTORY_CUSTOM_FIELD
@@ -1464,6 +1468,7 @@ RSpec.describe DiscoursePrometheusAlertReceiver::ReceiverController do
         before do
+          assignee_group.add(bob)
           payload["commonAnnotations"]["topic_assignee"] = "bobtheangryflower"
@@ -1490,15 +1495,13 @@ RSpec.describe DiscoursePrometheusAlertReceiver::ReceiverController do
         describe 'when group_topic_assignee is present in the payload' do
-          let(:group) { Fabricate(:group) }
           before do
-            group.users << [Fabricate(:user), Fabricate(:user)]
+            assignee_group.users << [Fabricate(:user), Fabricate(:user)]
             payload["commonAnnotations"].delete("topic_assignee")
           it 'should assign the topic correctly' do
-            [group.name, group.id].each do |id_or_name|
+            [assignee_group.name, assignee_group.id].each do |id_or_name|
               payload["commonAnnotations"]["group_topic_assignee"] = id_or_name
               expect do
@@ -1506,7 +1509,7 @@ RSpec.describe DiscoursePrometheusAlertReceiver::ReceiverController do
               end.to change { Topic.count }.by(1)
               expect(response.status).to eq(200)
-              expect(group.users.include?(topic.assigned_to_user)).to eq(true)
+              expect(assignee_group.users.include?(topic.assigned_to_user)).to eq(true)
               topic.destroy!
GitHub sha: 318c1917
