Fix the build.
diff --git a/config/initializers/006-ensure_login_hint.rb b/config/initializers/006-ensure_login_hint.rb
index af583da..d5c4259 100644
--- a/config/initializers/006-ensure_login_hint.rb
+++ b/config/initializers/006-ensure_login_hint.rb
@@ -1,23 +1,27 @@
 # Some sanity checking so we don't count on an unindexed column on boot
-if ActiveRecord::Base.connection.table_exists?(:users) &&
-   User.limit(20).count < 20 &&
-   User.where(admin: true).human_users.count == 0
+begin
+  if ActiveRecord::Base.connection.table_exists?(:users) &&
+     User.limit(20).count < 20 &&
+     User.where(admin: true).human_users.count == 0
-  notice =
-    if GlobalSetting.developer_emails.blank?
-      "Congratulations, you installed Discourse! Unfortunately, no administrator emails were defined during setup, so finalizing the configuration <a href='https://meta.discourse.org/t/create-admin-account-from-console/17274'>may be difficult</a>."
-    else
-      emails = GlobalSetting.developer_emails.split(",")
-      if emails.length > 1
-        emails = emails[0..-2].join(', ') << " or #{emails[-1]} "
+    notice =
+      if GlobalSetting.developer_emails.blank?
+        "Congratulations, you installed Discourse! Unfortunately, no administrator emails were defined during setup, so finalizing the configuration <a href='https://meta.discourse.org/t/create-admin-account-from-console/17274'>may be difficult</a>."
       else
-        emails = emails[0]
+        emails = GlobalSetting.developer_emails.split(",")
+        if emails.length > 1
+          emails = emails[0..-2].join(', ') << " or #{emails[-1]} "
+        else
+          emails = emails[0]
+        end
+        "Congratulations, you installed Discourse! Register a new admin account with #{emails} to finalize configuration."
-      "Congratulations, you installed Discourse! Register a new admin account with #{emails} to finalize configuration."
-    end
-  if notice != SiteSetting.global_notice
-    SiteSetting.global_notice = notice
-    SiteSetting.has_login_hint = true
+    if notice != SiteSetting.global_notice
+      SiteSetting.global_notice = notice
+      SiteSetting.has_login_hint = true
+    end
+rescue ActiveRecord::NoDatabaseError
+  # Database might not have been created
GitHub sha: 234e0f35
