fix the build
fix the build
diff --git a/app/assets/javascripts/discourse/app/components/group-card-contents.js b/app/assets/javascripts/discourse/app/components/group-card-contents.js
index 5f09b94..4820500 100644
--- a/app/assets/javascripts/discourse/app/components/group-card-contents.js
+++ b/app/assets/javascripts/discourse/app/components/group-card-contents.js
@@ -1,4 +1,4 @@
-import { alias, match, gt, or } from "@ember/object/computed";
+import { alias, match, gt } from "@ember/object/computed";
 import Component from "@ember/component";
 import { setting } from "discourse/lib/computed";
 import discourseComputed from "discourse-common/utils/decorators";
GitHub sha: 68fdfd76
