Fix the build.
Fix the build.
From 68578631378be1e7269f1f8cc3602e9f5fe1d248 Mon Sep 17 00:00:00 2001
Date: Fri, 19 Oct 2018 14:44:08 +0800
Subject: [PATCH] Fix the build.
diff --git a/spec/integration/discourse_prometheus_alert_receiver/receiver_controller_spec.rb b/spec/integration/discourse_prometheus_alert_receiver/receiver_controller_spec.rb
index f9c99c0..e788954 100644
--- a/spec/integration/discourse_prometheus_alert_receiver/receiver_controller_spec.rb
+++ b/spec/integration/discourse_prometheus_alert_receiver/receiver_controller_spec.rb
@@ -100,6 +100,7 @@ RSpec.describe DiscoursePrometheusAlertReceiver::ReceiverController do
     before do
       SiteSetting.queue_jobs = false
+      SiteSetting.tagging_enabled = true
     describe 'when token is missing or too short' do
GitHub
