FIX: Tooltip for unlisted topics wasn't shown in topic list
FIX: Tooltip for unlisted topics wasn’t shown in topic list
The locale key had to be renamed, because this key is also used as CSS class. The “invisible” CSS class makes the icon invisible. “unlisted” doesn’t have that effect.
diff --git a/app/assets/javascripts/discourse/components/topic-status.js.es6 b/app/assets/javascripts/discourse/components/topic-status.js.es6
index 2ab678f..1929cf1 100644
--- a/app/assets/javascripts/discourse/components/topic-status.js.es6
+++ b/app/assets/javascripts/discourse/components/topic-status.js.es6
@@ -65,7 +65,7 @@ export default Ember.Component.extend(
         "unpinned",
         this.get("canAct")
-      renderIconIf("topic.invisible", "eye-slash", "invisible");
+      renderIconIf("topic.invisible", "far-eye-slash", "unlisted");
diff --git a/app/assets/javascripts/discourse/raw-views/topic-status.js.es6 b/app/assets/javascripts/discourse/raw-views/topic-status.js.es6
index 6fd967b..6aeee4e 100644
--- a/app/assets/javascripts/discourse/raw-views/topic-status.js.es6
+++ b/app/assets/javascripts/discourse/raw-views/topic-status.js.es6
@@ -53,7 +53,7 @@ export default Ember.Object.extend({
     if (topic.get("invisible")) {
-      results.push({ icon: "eye-slash" });
+      results.push({ icon: "far-eye-slash", key: "unlisted" });
     results.forEach(result => {
diff --git a/app/assets/javascripts/discourse/widgets/topic-status.js.es6 b/app/assets/javascripts/discourse/widgets/topic-status.js.es6
index ff03d82..2650563 100644
--- a/app/assets/javascripts/discourse/widgets/topic-status.js.es6
+++ b/app/assets/javascripts/discourse/widgets/topic-status.js.es6
@@ -39,7 +39,7 @@ export default createWidget("topic-status", {
     renderIconIf("pinned", "thumbtack", "pinned");
     renderIconIf("unpinned", "thumbtack", "unpinned");
-    renderIconIf("invisible", "eye-slash", "invisible");
+    renderIconIf("invisible", "far-eye-slash", "unlisted");
     return result;
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index a0ab970..12d29ad 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -2512,7 +2512,7 @@ en:
       pinned:
         title: "Pinned"
         help: "This topic is pinned for you; it will display at the top of its category"
-      invisible:
+      unlisted:
         help: "This topic is unlisted; it will not be displayed in topic lists, and can only be accessed via a direct link"
     posts: "Posts"
GitHub sha: 70cdb421
