FIX: tooltip is no longer used
It has been deprecated and now it’s time to remove it.
diff --git a/app/assets/javascripts/discourse/app/lib/tooltip.js b/app/assets/javascripts/discourse/app/lib/tooltip.js
deleted file mode 100644
index 5242370..0000000
--- a/app/assets/javascripts/discourse/app/lib/tooltip.js
+++ /dev/null
@@ -1,109 +0,0 @@
-import deprecated from "discourse-common/lib/deprecated";
-import { escapeExpression } from "discourse/lib/utilities";
-const fadeSpeed = 300;
-const tooltipID = "#discourse-tooltip";
-export function showTooltip(e) {
-  const $this = $(e.currentTarget),
-    $parent = $this.offsetParent();
-  // html tooltip are risky try your best to sanitize anything
-  // displayed as html to avoid XSS attacks
-  const content = $this.attr("data-tooltip")
-    ? escapeExpression($this.attr("data-tooltip"))
-    : $this.attr("data-html-tooltip") || "";
-  const retina =
-    window.devicePixelRatio && window.devicePixelRatio > 1
-      ? "class='retina'"
-  let pos = $this.offset();
-  const delta = $parent.offset();
-  pos.top -= delta.top;
-  pos.left -= delta.left;
-  hideTooltip();
-  $this.after(`
-    <div id="discourse-tooltip" ${retina}>
-      <div class="tooltip-pointer"></div>
-      <div class="tooltip-content">${content}</div>
-    </div>
-  $(window).on("click.discourse", event => {
-    if ($(event.target).closest(tooltipID).length === 0) {
-      $(tooltipID).remove();
-      $(window).off("click.discourse");
-    return true;
-  const $tooltip = $(tooltipID);
-  $tooltip.css({ top: 0, left: 0 });
-  let left = pos.left - $tooltip.width() / 2 + $this.width() / 2;
-  if (left < 0) {
-    $tooltip.find(".tooltip-pointer").css({
-      "margin-left": left * 2 + "px"
-    left = 0;
-  // also do a right margin fix
-  const parentWidth = $parent.width();
-  if (left + $tooltip.width() > parentWidth) {
-    let oldLeft = left;
-    left = parentWidth - $tooltip.width();
-      "margin-left": (oldLeft - left) * 2 + "px"
-  $tooltip.css({
-    top: pos.top + 5 + "px",
-    left: left + "px"
-  $tooltip.fadeIn(fadeSpeed);
-  return false;
-export function hideTooltip() {
-  $(tooltipID)
-    .fadeOut(fadeSpeed)
-    .remove();
-export function registerTooltip(jqueryContext) {
-  deprecated("tooltip is getting deprecated. Use d-popover instead");
-  if (jqueryContext.length) {
-    jqueryContext.off("click").on("click", event => showTooltip(event));
-export function registerHoverTooltip(jqueryContext) {
-    jqueryContext
-      .off("mouseenter mouseleave click")
-      .on("mouseenter click", showTooltip)
-      .on("mouseleave", hideTooltip);
-export function unregisterTooltip(jqueryContext) {
-    jqueryContext.off("click");
-export function unregisterHoverTooltip(jqueryContext) {
-    jqueryContext.off("mouseenter mouseleave click");
diff --git a/test/javascripts/lib/tooltip-test.js b/test/javascripts/lib/tooltip-test.js
index 5e69515..0000000
--- a/test/javascripts/lib/tooltip-test.js
+++ /dev/null
@@ -1,60 +0,0 @@
-import { registerTooltip, registerHoverTooltip } from "discourse/lib/tooltip";
-import { fixture } from "helpers/qunit-helpers";
-// prettier-ignore
-QUnit.module("lib:tooltip", {
-  beforeEach() {
-    fixture().html(
-        <a class='test-text-link' data-tooltip='XSS<s onmouseover\=alert(document.domain)>XSS'>test</a>
-        <a class='test-html-link' data-html-tooltip='<p>test</p>'>test</a>
-QUnit.test("text support", async assert => {
-  const $testTextLink = fixture(".test-text-link");
-  registerTooltip($testTextLink);
-  await $testTextLink.click();
-  assert.equal(
-    fixture(".tooltip-content")
-      .html()
-      .trim(),
-    "XSS&lt;s onmouseover=alert(document.domain)&gt;XSS",
-    "it prevents XSS injection"
-  assert.equal(
-      .text()
-      .trim(),
-    "XSS<s onmouseover=alert(document.domain)>XSS",
-    "it returns content as plain text"
-QUnit.test("html support", async assert => {
-  const $testHtmlLink = fixture(".test-html-link");
-  registerHoverTooltip($testHtmlLink);
-  await $testHtmlLink.click();
-  assert.equal(
-      .html()
-      .trim(),
-    "<p>test</p>",
-    "it doesn’t escape HTML"
-  assert.equal(
-      .text()
-      .trim(),
-    "test",
GitHub sha: 0ecca3a2
