FIX: topic_creator accepts participant_count in import mode (PR #10632)
The issue mentioned here: https://meta.discourse.org/t/imported-private-discussion-doesnt-appear-in-the-author-inbox/163252
participant_count is important to attribute for private messages. If they are imported, we should allow them to set that attribute.
A workaround would be evaluating update_statistics method on each Topic but that is less performant.
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/imported-private-discussion-doesnt-appear-in-the-author-inbox/163252/7
