FIX: typo in discourse
occurences → occurrences
diff --git a/script/discourse b/script/discourse
index 32b0bb3..1d4e4ff 100755
--- a/script/discourse
+++ b/script/discourse
@@ -34,9 +34,9 @@ class DiscourseCLI < Thor
     require 'db_helper'
     if options[:regex]
-      puts "Rewriting all occurences of #{from} to #{to} using regexp_replace"
+      puts "Rewriting all occurrences of #{from} to #{to} using regexp_replace"
     else
-      puts "Rewriting all occurences of #{from} to #{to}"
+      puts "Rewriting all occurrences of #{from} to #{to}"
     puts "THIS TASK WILL REWRITE DATA, ARE YOU SURE (type YES)"
     puts "WILL RUN ON ALL #{RailsMultisite::ConnectionManagement.all_dbs.length} DBS" if options[:global]
GitHub sha: 88da06cba077e36f2d639dbe88a8dd3bca84a210
This commit appears in #13585 which was approved by eviltrout. It was merged by eviltrout.
