FIX: Unpause sidekiq before adding uploads to backup
tar exits with status 1 when uploads are modified or deleted by a sidekiq job, so we need to treat it like status 0.
According to the documentation it should be safe to ignore status 1 (“Some files differ”):
If tar was given --create',–append’ or `–update’ option, this exit code means that some files were changed while being archived and so the resulting archive does not contain the exact copy of the file set.
Status 2 (“Fatal error”) still results in an exception.
diff --git a/lib/backup_restore/backuper.rb b/lib/backup_restore/backuper.rb
index cdda8a1..e9d5c31 100644
--- a/lib/backup_restore/backuper.rb
+++ b/lib/backup_restore/backuper.rb
@@ -37,14 +37,14 @@ module BackupRestore
       dump_public_schema
+      unpause_sidekiq
       disable_readonly_mode
       ### READ-ONLY / END ###
       log "Finalizing backup..."
       @with_uploads ? create_archive : move_dump_backup
-      unpause_sidekiq
       upload_archive
       after_create_hook
@@ -237,8 +237,8 @@ module BackupRestore
       FileUtils.cd(File.join(Rails.root, "public")) do
         if File.directory?(upload_directory)
           Discourse::Utils.execute_command(
-            'tar', '--append', '--dereference', '--warning=no-file-changed', '--file', tar_filename, upload_directory,
-            failure_message: "Failed to archive uploads."
+            'tar', '--append', '--dereference', '--file', tar_filename, upload_directory,
+            failure_message: "Failed to archive uploads.", success_status_codes: [0, 1]
         else
           log "No uploads found, skipping archiving uploads..."
diff --git a/lib/discourse.rb b/lib/discourse.rb
index d681ddb..7f5b018 100644
--- a/lib/discourse.rb
+++ b/lib/discourse.rb
@@ -21,10 +21,10 @@ module Discourse
   class Utils
-    def self.execute_command(*command, failure_message: "")
+    def self.execute_command(*command, failure_message: "", success_status_codes: [0])
       stdout, stderr, status = Open3.capture3(*command)
-      if !status.success?
+      if !status.exited? || !success_status_codes.include?(status.exitstatus)
         failure_message = "#{failure_message}\n" if !failure_message.blank?
         raise "#{caller[0]}: #{failure_message}#{stderr}"
GitHub sha: 220944a3
:+1:
