FIX: update normalize css from 3.0.1 to 8.0.1 (#10141)
It is a second attempt to this update. First one was reverted here https://github.com/discourse/discourse/pull/8618
We noticed a problem that like counter had incorrect colour on mobile.
I added a missing rule to the bottom of the file (that rule existed in normalize-3 and was removed in normalize-8)
button,
input,
optgroup,
select,
textarea {
  color: inherit;
diff --git a/app/assets/stylesheets/vendor/normalize.scss b/app/assets/stylesheets/vendor/normalize.scss
index ad7de2b..6980a9b 100644
--- a/app/assets/stylesheets/vendor/normalize.scss
+++ b/app/assets/stylesheets/vendor/normalize.scss
@@ -1,243 +1,515 @@
-/*! normalize.css v3.0.1 | MIT License | git.io/normalize */
+/*! normalize.css v8.0.1 | MIT License | github.com/necolas/normalize.css */
+/* Document
- * 1. Set default font family to sans-serif.
- * 2. Prevent iOS text size adjust after orientation change, without disabling
- *    user zoom.
+ * 1. Correct the line height in all browsers.
+ * 2. Prevent adjustments of font size after orientation changes in iOS.
 html {
-  font-family: sans-serif; /* 1 */
-  -ms-text-size-adjust: 100%; /* 2 */
+  line-height: 1.15; /* 1 */
   -webkit-text-size-adjust: 100%; /* 2 */
+/* Sections
- * Remove default margin.
+ * Remove the margin in all browsers.
 body {
   margin: 0;
-/* HTML5 display definitions
- * Correct `block` display not defined for any HTML5 element in IE 8/9.
- * Correct `block` display not defined for `details` or `summary` in IE 10/11 and Firefox.
- * Correct `block` display not defined for `main` in IE 11.
+ * Render the `main` element consistently in IE.
-article,
-aside,
-details,
-figcaption,
-figure,
-footer,
-header,
-hgroup,
-main,
-nav,
-section,
-summary {
+main {
   display: block;
- * 1. Correct `inline-block` display not defined in IE 8/9.
- * 2. Normalize vertical alignment of `progress` in Chrome, Firefox, and Opera.
+ * Correct the font size and margin on `h1` elements within `section` and
+ * `article` contexts in Chrome, Firefox, and Safari.
-audio,
-canvas,
-progress,
-video {
-  display: inline-block; /* 1 */
-  vertical-align: baseline; /* 2 */
+h1 {
+  font-size: 2em;
+  margin: 0.67em 0;
+/* Grouping content
- * Prevent modern browsers from displaying `audio` without controls.
- * Remove excess height in iOS 5 devices.
+ * 1. Add the correct box sizing in Firefox.
+ * 2. Show the overflow in Edge and IE.
-audio:not([controls]) {
-  display: none;
-  height: 0;
+hr {
+  box-sizing: content-box; /* 1 */
+  height: 0; /* 1 */
+  overflow: visible; /* 2 */
- * Address `[hidden]` styling not present in IE 8/9/10.
- * Hide the `template` element in IE 8/9/11, Safari, and Firefox < 22.
+ * 1. Correct the inheritance and scaling of font size in all browsers.
+ * 2. Correct the odd `em` font sizing in all browsers.
-[hidden],
-template {
-  display: none;
+pre {
+  font-family: monospace, monospace; /* 1 */
+  font-size: 1em; /* 2 */
-/* Links
+/* Text-level semantics
- * Remove the gray background color from active links in IE 10.
+ * Remove the gray background on active links in IE 10.
 a {
-  background: transparent;
+  background-color: transparent;
- * Improve readability when focused and also mouse hovered in all browsers.
+ * 1. Remove the bottom border in Chrome 57-
+ * 2. Add the correct text decoration in Chrome, Edge, IE, Opera, and Safari.
-a:active,
-a:hover {
-  outline: 0;
+abbr[title] {
+  border-bottom: none; /* 1 */
+  text-decoration: underline; /* 2 */
+  text-decoration: underline dotted; /* 2 */
-/* Text-level semantics
+ * Add the correct font weight in Chrome, Edge, and Safari.
+b,
+strong {
+  font-weight: bolder;
+code,
+kbd,
+samp {
+ * Add the correct font size in all browsers.
+small {
+  font-size: 80%;
+ * Prevent `sub` and `sup` elements from affecting the line height in
+ * all browsers.
+sub,
+sup {
+  font-size: 75%;
+  line-height: 0;
+  position: relative;
+  vertical-align: baseline;
+sub {
+  bottom: -0.25em;
+sup {
+  top: -0.5em;
+/* Embedded content
- * Address styling not present in IE 8/9/10/11 & Edge
+ * Remove the border on images inside links in IE 10.
- abbr[title], acronym[title] {
-  text-decoration: underline;
-  text-decoration-style: dotted;
+img {
+  border-style: none;
+/* Forms
- * Address style set to `bolder` in Firefox 4+, Safari, and Chrome.
+ * 1. Change the font styles in all browsers.
+ * 2. Remove the margin in Firefox and Safari.
-b,
-strong {
-  font-weight: bold;
+button,
+input,
+optgroup,
+select,
+textarea {
+  font-family: inherit; /* 1 */
+  font-size: 100%; /* 1 */
+  margin: 0; /* 2 */
- * Address styling not present in Safari and Chrome.
+ * Show the overflow in IE.
+ * 1. Show the overflow in Edge.
-dfn {
-  font-style: italic;
+button,
+input { /* 1 */
- * Address variable `h1` font-size and margin within `section` and `article`
- * contexts in Firefox 4+, Safari, and Chrome.
+ * Remove the inheritance of text transform in Edge, Firefox, and IE.
+ * 1. Remove the inheritance of text transform in Firefox.
-h1 {
-  font-size: 1.7511em;
-  margin: 0.67em 0;
+button,
+select { /* 1 */
+  text-transform: none;
- * Address styling not present in IE 8/9.
+ * Correct the inability to style clickable types in iOS and Safari.
-mark {
-  background: #ff0;
-  color: #000;
+button,
+[type="button"],
+[type="reset"],
+[type="submit"] {
+  -webkit-appearance: button;
- * Address inconsistent and variable font size in all browsers.
+ * Remove the inner border and padding in Firefox.
-small {
-  font-size: 80%;
+button::-moz-focus-inner,
+[type="button"]::-moz-focus-inner,
+[type="reset"]::-moz-focus-inner,
+[type="submit"]::-moz-focus-inner {
+  padding: 0;
- * Prevent `sub` and `sup` affecting `line-height` in all browsers.
+ * Restore the focus styles unset by the previous rule.
-sub,
-sup {
-  font-size: 75%;
-  line-height: 0;
-  position: relative;
+button:-moz-focusring,
+[type="button"]:-moz-focusring,
+[type="reset"]:-moz-focusring,
+[type="submit"]:-moz-focusring {
+  outline: 1px dotted ButtonText;
+ * Correct the padding in Firefox.
+fieldset {
+  padding: 0.35em 0.75em 0.625em;
+ * 1. Correct the text wrapping in Edge and IE.
+ * 2. Correct the color inheritance from `fieldset` elements in IE.
+ * 3. Remove the padding so developers are not caught out when they zero out
+ *    `fieldset` elements in all browsers.
+legend {
+  box-sizing: border-box; /* 1 */
+  color: inherit; /* 2 */
+  display: table; /* 1 */
+  max-width: 100%; /* 1 */
+  padding: 0; /* 3 */
+  white-space: normal; /* 1 */
+ * Add the correct vertical alignment in Chrome, Firefox, and Opera.
+progress {
-sup {
-  top: -0.5em;
+ * Remove the default vertical scrollbar in IE 10+.
+textarea {
+  overflow: auto;
-sub {
-  bottom: -0.25em;
+ * 1. Add the correct box sizing in IE 10.
+ * 2. Remove the padding in IE 10.
+[type="checkbox"],
+[type="radio"] {
+  padding: 0; /* 2 */
-/* Embedded content
+ * Correct the cursor style of increment and decrement buttons in Chrome.
GitHub sha: 1fd3a30a
This commit appears in #10141 which was approved by eviltrout. It was merged by lis2.
Restore ‘pointer’ cursor on buttons
