FIX: Update raw and cooked immediate after edit (#13387)
  • Revert “DEV: skips three tests following cc1e73 (#13386)”
This reverts commit 2be201660a4c2fef5a714a94fe9f66341f9a09f0.
  • FIX: Do not refresh post stream twice
This also improves the test suite and simulates a long running request
  • FIX: Update local copy of raw
diff --git a/app/assets/javascripts/discourse/app/models/composer.js b/app/assets/javascripts/discourse/app/models/composer.js
index 8aa68da..e791154 100644
--- a/app/assets/javascripts/discourse/app/models/composer.js
+++ b/app/assets/javascripts/discourse/app/models/composer.js
@@ -929,6 +929,7 @@ const Composer = RestModel.extend({
   editPost(opts) {
     const post = this.post;
+    const oldRaw = post.raw;
     const oldCooked = post.cooked;
     let promise = Promise.resolve();
@@ -970,16 +971,14 @@ const Composer = RestModel.extend({
     this.set("composeState", SAVING);
     const rollback = throwAjaxError((error) => {
-      post.setProperties({ cooked: oldCooked, staged: false });
-      this.appEvents.trigger("post-stream:refresh", { id: post.id });
+      post.setProperties({ raw: oldRaw, cooked: oldCooked });
       this.set("composeState", OPEN);
       if (error.jqXHR && error.jqXHR.status === 409) {
         this.set("editConflict", true);
-    post.setProperties({ cooked: props.cooked, staged: true });
+    post.setProperties({ raw: props.raw, cooked: props.cooked, staged: true });
     return promise
diff --git a/app/assets/javascripts/discourse/tests/acceptance/composer-edit-conflict-test.js b/app/assets/javascripts/discourse/tests/acceptance/composer-edit-conflict-test.js
index 96f9702..6eb7be8 100644
--- a/app/assets/javascripts/discourse/tests/acceptance/composer-edit-conflict-test.js
+++ b/app/assets/javascripts/discourse/tests/acceptance/composer-edit-conflict-test.js
@@ -14,26 +14,23 @@ acceptance("Composer - Edit conflict", function (needs) {
-  QUnit.skip(
-    "Edit a post that causes an edit conflict",
-    async function (assert) {
-      await visit("/t/internationalization-localization/280");
-      await click(".topic-post:nth-of-type(1) button.show-more-actions");
-      await click(".topic-post:nth-of-type(1) button.edit");
-      await fillIn(".d-editor-input", "this will 409");
-      await click("#reply-control button.create");
-      assert.equal(
-        queryAll("#reply-control button.create").text().trim(),
-        I18n.t("composer.overwrite_edit"),
-        "it shows the overwrite button"
-      assert.ok(
-        queryAll("#draft-status .d-icon-user-edit"),
-        "error icon should be there"
-      await click(".modal .btn-primary");
+  test("Edit a post that causes an edit conflict", async function (assert) {
+    await visit("/t/internationalization-localization/280");
+    await click(".topic-post:nth-of-type(1) button.show-more-actions");
+    await click(".topic-post:nth-of-type(1) button.edit");
+    await fillIn(".d-editor-input", "this will 409");
+    await click("#reply-control button.create");
+    assert.equal(
+      queryAll("#reply-control button.create").text().trim(),
+      I18n.t("composer.overwrite_edit"),
+      "it shows the overwrite button"
+    assert.ok(
+      queryAll("#draft-status .d-icon-user-edit"),
+      "error icon should be there"
+    await click(".modal .btn-primary");
   test("Should not send originalText when posting a new reply", async function (assert) {
diff --git a/app/assets/javascripts/discourse/tests/acceptance/composer-test.js b/app/assets/javascripts/discourse/tests/acceptance/composer-test.js
index 5fc43fe..c499f1a 100644
--- a/app/assets/javascripts/discourse/tests/acceptance/composer-test.js
+++ b/app/assets/javascripts/discourse/tests/acceptance/composer-test.js
@@ -348,15 +348,25 @@ acceptance("Composer", function (needs) {
-  QUnit.skip("Editing a post stages new content", async function (assert) {
+  test("Editing a post stages new content", async function (assert) {
     await fillIn(".d-editor-input", "will return empty json");
     await fillIn("#reply-title", "This is the new text for the title");
+    // when this promise resolves, the request had already started because
+    // this promise will be resolved by the pretender
+    const promise = new Promise((resolve) => {
+      window.resolveLastPromise = resolve;
+    // click to trigger the save, but wait until the request starts
+    click("#reply-control button.create");
+    await promise;
+    // at this point, request is in flight, so post is staged
     assert.equal(count(".topic-post.staged"), 1);
     assert.ok(
       find(".topic-post:nth-of-type(1)")[0].className.includes("staged")
@@ -365,28 +375,31 @@ acceptance("Composer", function (needs) {
       find(".topic-post.staged .cooked").text().trim(),
+    // finally, finish request and wait for last render
+    window.resolveLastPromise();
+    assert.equal(count(".topic-post.staged"), 0);
-  QUnit.skip(
-    "Editing a post can rollback to old content",
+  test("Editing a post can rollback to old content", async function (assert) {
-      await fillIn("#reply-title", "This is the new text for the title");
+    await fillIn("#reply-title", "This is the new text for the title");
-      assert.ok(!exists(".topic-post.staged"));
-      assert.equal(
-        find(".topic-post .cooked")[0].innerText,
-        "Any plans to support localization of UI elements, so that I (for example) could set up a completely German speaking forum?"
+    assert.ok(!exists(".topic-post.staged"));
+    assert.equal(
+      find(".topic-post .cooked")[0].innerText,
+      "Any plans to support localization of UI elements, so that I (for example) could set up a completely German speaking forum?"
-      await click(".bootbox.modal .btn-primary");
+    await click(".bootbox.modal .btn-primary");
   test("Composer can switch between edits", async function (assert) {
     await visit("/t/this-is-a-test-topic/9");
diff --git a/app/assets/javascripts/discourse/tests/helpers/create-pretender.js b/app/assets/javascripts/discourse/tests/helpers/create-pretender.js
index 2b843d6..b312f02 100644
--- a/app/assets/javascripts/discourse/tests/helpers/create-pretender.js
+++ b/app/assets/javascripts/discourse/tests/helpers/create-pretender.js
@@ -1,6 +1,7 @@
 import Pretender from "pretender";
 import User from "discourse/models/user";
 import getURL from "discourse-common/lib/get-url";
+import { Promise } from "rsvp";
 export function parsePostData(query) {
   const result = {};
@@ -479,12 +480,15 @@ export function applyDefaultHandlers(pretender) {
   pretender.put("/posts/:post_id/recover", success);
   pretender.get("/posts/:post_id/expand-embed", success);
-  pretender.put("/posts/:post_id", (request) => {
+  pretender.put("/posts/:post_id", async (request) => {
     const data = parsePostData(request.requestBody);
     if (data.post.raw === "this will 409") {
       return response(409, { errors: ["edit conflict"] });
GitHub sha: 3a3a2abdb7b49818d31ab4b71f524f3387fbd0e6
This commit appears in #13387 which was approved by SamSaffron. It was merged by SamSaffron.
