FIX: use 'about.json' endpoint instead of using ember model to get the data.
FIX: use ‘about.json’ endpoint instead of using ember model to get the data.
diff --git a/app/assets/javascripts/admin/mixins/setting-component.js.es6 b/app/assets/javascripts/admin/mixins/setting-component.js.es6
index eaf5b356b6..bd73175899 100644
--- a/app/assets/javascripts/admin/mixins/setting-component.js.es6
+++ b/app/assets/javascripts/admin/mixins/setting-component.js.es6
@@ -4,8 +4,8 @@ import { categoryLinkHTML } from "discourse/helpers/category-link";
 import { on } from "@ember/object/evented";
 import Mixin from "@ember/object/mixin";
 import showModal from "discourse/lib/show-modal";
-import AboutRoute from "discourse/routes/about";
 import { Promise } from "rsvp";
+import { ajax } from "discourse/lib/ajax";
 const CUSTOM_TYPES = [
   "bool",
@@ -151,22 +151,20 @@ export default Mixin.create({
       const key = this.buffered.get("setting");
       if (defaultUserPreferences.includes(key)) {
-        AboutRoute.create()
-          .model()
-          .then(result => {
-            const controller = showModal("site-setting-default-categories", {
-              model: {
-                count: result.stats.user_count,
-                key: key.replace(/_/g, " ")
-              admin: true
-            controller.set("onClose", () => {
-              this.updateExistingUsers = controller.updateExistingUsers;
-              this.send("save");
+        ajax("/about.json").then(result => {
+          const controller = showModal("site-setting-default-categories", {
+            model: {
+              count: result.about.stats.user_count,
+              key: key.replace(/_/g, " ")
+            admin: true
+          controller.set("onClose", () => {
+            this.updateExistingUsers = controller.updateExistingUsers;
+            this.send("save");
       } else {
         this.send("save");
GitHub sha: edec9228
Why do we need to use the about.json endpoint?
To get the total number of users. Anyway, I’m going to change the behavior here. Instead of displaying the total number of users on the site I will display the total number of users going to be affected by the site setting change.
UX: instead of total user count display only the count of users going to be affected.
