FIX: Use array to keep best link for each onebox (PR #13717)
Using an object does not work well because HTML elements are cannot be used as keys in all browsers or situations.
GitHub
Wouldn’t it be better to use Map() instead?
I agree with @CvX, looks like Map() would be a better fit here - Map - JavaScript | MDN
TIL about Map. I did not know such thing existed and by the looks of it, it should be always preferred over {}.
Depends no the use case. Map() is a pretty recent feature in JS and wasn’t available everywhere until not that long ago… So {} was used as a map instead.
It’s been available everywhere (even in IE!) for 7 years or more now. :grin:
What now? :exploding_head:
Got that part wrong then :man_facepalming:
