FIX: Use Ember’s debounce on stable. (#96)
We need to wrap the new debounce function inside a try block to avoid throwing a “module not found” exception.
diff --git a/assets/javascripts/discourse/components/explorer-schema.js.es6 b/assets/javascripts/discourse/components/explorer-schema.js.es6
index 71ec4fb..85a0d38 100644
--- a/assets/javascripts/discourse/components/explorer-schema.js.es6
+++ b/assets/javascripts/discourse/components/explorer-schema.js.es6
@@ -2,8 +2,7 @@ import {
default as computed,
observes,
} from "discourse-common/utils/decorators";
-import discourseDebounce from "discourse-common/lib/debounce";
-import debounce from "@ember/runloop";
+import { debounce } from "@ember/runloop";
export default Ember.Component.extend({
actions: {
@@ -116,7 +115,11 @@ export default Ember.Component.extend({
@observes("filter")
triggerFilter() {
// TODO: Use discouseDebounce after the 2.7 release.
- let debounceFunc = discourseDebounce || debounce;
+ let debounceFunc = debounce;
+ try {
+ debounceFunc = require("discourse-common/lib/debounce").default;
+ } catch (_) {}
debounceFunc(
this,
GitHub sha: 50e62d84
