FIX: Use ENV values instead of 'S3Helper.s3_options' in migrate_to_s3
FIX: Use ENV values instead of ‘S3Helper.s3_options’ in migrate_to_s3
This commit makes the rake task operational for all regions for s3. If we declare s3_endpoint as https://s3.amazonaws.com while creating an instance of Aws::S3::Client, head_bucket fails for all s3 regions apart from us-east-1. The commit manually defines all parameters for Aws::S3::Client apart from s3_endpoint to bypass this problem make this task usable for AWS S3.
Removing s3_endpoint from the payload means that custom endpoints like Minio/DO Spaces for will not work in the meantime and we’ll have to add support for a custom s3_endpoint in the future.
This commit follows up on 60790eb0.
diff --git a/lib/tasks/uploads.rake b/lib/tasks/uploads.rake
index 37b5425..cb99d69 100644
--- a/lib/tasks/uploads.rake
+++ b/lib/tasks/uploads.rake
@@ -244,14 +244,18 @@ def migrate_to_s3
     exit 3
-  bucket_has_folder_path = true if GlobalSetting.s3_bucket.include? "/"
-  s3 = Aws::S3::Client.new(S3Helper.s3_options(GlobalSetting))
+  bucket_has_folder_path = true if ENV["DISCOURSE_S3_BUCKET"].include? "/"
+  s3 = Aws::S3::Client.new(
+    region: ENV["DISCOURSE_S3_REGION"],
+    access_key_id: ENV["DISCOURSE_S3_ACCESS_KEY_ID"],
+    secret_access_key: ENV["DISCOURSE_S3_SECRET_ACCESS_KEY"])
   if bucket_has_folder_path
-    bucket, folder = S3Helper.get_bucket_and_folder_path(GlobalSetting.s3_bucket)
+    bucket, folder = S3Helper.get_bucket_and_folder_path(ENV["DISCOURSE_S3_BUCKET"])
     folder = File.join(folder, "/")
   else
-    bucket, folder = GlobalSetting.s3_bucket, ""
+    bucket, folder = ENV["DISCOURSE_S3_BUCKET"], ""
   begin
GitHub sha: 97e17fe0
FIX: Use s3_endpoint in migrate_to_s3 when not using S3
