FIX: Use filtered posts when determining the next page
This bug was causing some unusual behavior when the last post is filtered (e.g. from an ignored user). In some situations this would cause suggested topics to be omitted from the payload.
The next_page specs have been updated to remove most of the stubs
diff --git a/lib/topic_view.rb b/lib/topic_view.rb
index 0f26832202..b95254d14a 100644
--- a/lib/topic_view.rb
+++ b/lib/topic_view.rb
@@ -152,7 +152,7 @@ class TopicView
   def next_page
     @next_page ||= begin
-      if last_post && (@topic.highest_post_number > last_post.post_number)
+      if last_post && highest_post_number && (highest_post_number > last_post.post_number)
         @page + 1
diff --git a/spec/components/topic_view_spec.rb b/spec/components/topic_view_spec.rb
index ce1f0e844a..2d6948c6b8 100644
--- a/spec/components/topic_view_spec.rb
+++ b/spec/components/topic_view_spec.rb
@@ -48,6 +48,11 @@ describe TopicView do
         expect(tv.filtered_post_ids).to eq([post.id, post2.id])
+      it "returns nil for next_page" do
+        tv = TopicView.new(topic.id, evil_trout)
+        expect(tv.next_page).to eq(nil)
+      end
       describe "when an ignored user made the original post" do
         let!(:post) { Fabricate(:post, topic: topic, user: user) }
@@ -245,22 +250,16 @@ describe TopicView do
     describe "#next_page" do
-      let(:p2) { stub(post_number: 2) }
-      let(:topic) do
-        topic = create_topic
-        topic.stubs(:highest_post_number).returns(5)
-        topic
-      end
+      let!(:post) { Fabricate(:post, topic: topic, user: user) }
+      let!(:post2) { Fabricate(:post, topic: topic, user: user) }
+      let!(:post3) { Fabricate(:post, topic: topic, user: user) }
       before do
-        TopicView.any_instance.expects(:find_topic).with(1234).returns(topic)
-        TopicView.any_instance.stubs(:filter_posts)
-        TopicView.any_instance.stubs(:last_post).returns(p2)
         TopicView.stubs(:chunk_size).returns(2)
       it "should return the next page" do
-        expect(TopicView.new(1234, user).next_page).to eql(2)
+        expect(TopicView.new(topic.id, user).next_page).to eql(2)
GitHub sha: be1510b0
