FIX: use Handlebars 4.0.12
Use 4.0.12 for both versions of Handlebars (runtime and not)
diff --git a/package.json b/package.json
index 2fada31..8aa4b7e 100644
--- a/package.json
+++ b/package.json
@@ -11,7 +11,7 @@
     "bootbox": "3.2.0",
     "chart.js": "2.7.2",
     "favcount": "https://github.com/chrishunt/favcount",
-    "handlebars": "4.0.5",
+    "handlebars": "4.0.12",
     "highlight.js": "https://github.com/highlightjs/highlight.js",
     "htmlparser": "https://github.com/tautologistics/node-htmlparser",
     "intersection-observer": "^0.5.1",
diff --git a/vendor/assets/javascripts/handlebars.js b/vendor/assets/javascripts/handlebars.js
index e5dd19a..ad93d3b 100644
--- a/vendor/assets/javascripts/handlebars.js
+++ b/vendor/assets/javascripts/handlebars.js
@@ -1630,7 +1630,7 @@ return /******/ (function(modules) { // webpackBootstrap
 	        terminals_: { 2: "error", 5: "EOF", 14: "COMMENT", 15: "CONTENT", 18: "END_RAW_BLOCK", 19: "OPEN_RAW_BLOCK", 23: "CLOSE_RAW_BLOCK", 29: "OPEN_BLOCK", 33: "CLOSE", 34: "OPEN_INVERSE", 39: "OPEN_INVERSE_CHAIN", 44: "INVERSE", 47: "OPEN_ENDBLOCK", 48: "OPEN", 51: "OPEN_UNESCAPED", 54: "CLOSE_UNESCAPED", 55: "OPEN_PARTIAL", 60: "OPEN_PARTIAL_BLOCK", 65: "OPEN_SEXPR", 68: "CLOSE_SEXPR", 72: "ID", 73: "EQUALS", 75: "OPEN_BLOCK_PARAMS", 77: "CLOSE_BLOCK_PARAMS", 80: "STRING", 81: "NUMBER", 82: "BOOLEAN", 83: "UNDEFINED", 84: "NULL", 85: "DATA", 87: "SEP" },
 	        productions_: [0, [3, 2], [4, 1], [7, 1], [7, 1], [7, 1], [7, 1], [7, 1], [7, 1], [7, 1], [13, 1], [10, 3], [16, 5], [9, 4], [9, 4], [24, 6], [27, 6], [38, 6], [43, 2], [45, 3], [45, 1], [26, 3], [8, 5], [8, 5], [11, 5], [12, 3], [59, 5], [63, 1], [63, 1], [64, 5], [69, 1], [71, 3], [74, 3], [20, 1], [20, 1], [20, 1], [20, 1], [20, 1], [20, 1], [20, 1], [56, 1], [56, 1], [79, 2], [78, 1], [86, 3], [86, 1], [6, 0], [6, 2], [17, 1], [17, 2], [21, 0], [21, 2], [22, 0], [22, 1], [25, 0], [25, 1], [28, 0], [28, 1], [30, 0], [30, 2], [31, 0], [31, 1], [32, 0], [32, 1], [35, 0], [35, 2], [36, 0], [36, 1], [37, 0], [37, 1], [40, 0], [40, 2], [41, 0], [41, 1], [42, 0], [42, 1], [46, 0], [46, 1], [49, 0], [49, 2], [50, 0], [50, 1], [52, 0], [52, 2], [53, 0], [53, 1], [57, 0], [57, 2], [58, 0], [58, 1], [61, 0], [61, 2], [62, 0], [62, 1], [66, 0], [66, 2], [67, 0], [67, 1], [70, 1], [70, 2], [76, 1], [76, 2]],
 	        performAction: function anonymous(yytext, yyleng, yylineno, yy, yystate, $$, _$
 	            var $0 = $$.length - 1;
 	            switch (yystate) {
@@ -2168,7 +2168,7 @@ return /******/ (function(modules) { // webpackBootstrap
 	        lexer.options = {};
 	        lexer.performAction = function anonymous(yy, yy_, $avoiding_name_collisions, YY_START
 	            function strip(start, end) {
 	                return yy_.yytext = yy_.yytext.substr(start, yy_.yyleng - end);
@@ -4835,4 +4835,4 @@ return /******/ (function(modules) { // webpackBootstrap
\ No newline at end of file
diff --git a/vendor/assets/javascripts/handlebars.runtime.js b/vendor/assets/javascripts/handlebars.runtime.js
index 95049f3..f898d31 100644
--- a/vendor/assets/javascripts/handlebars.runtime.js
+++ b/vendor/assets/javascripts/handlebars.runtime.js
@@ -1,8 +1,9 @@
- handlebars v4.0.5
+ @license
+ handlebars v4.0.12
-Copyright (C) 2011-2015 by Yehuda Katz
+Copyright (C) 2011-2017 by Yehuda Katz
 Permission is hereby granted, free of charge, to any person obtaining a copy
 of this software and associated documentation files (the "Software"), to deal
@@ -22,7 +23,6 @@ LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 THE SOFTWARE.
-@license
 (function webpackUniversalModuleDefinition(root, factory) {
 	if(typeof exports === 'object' && typeof module === 'object')
@@ -78,7 +78,7 @@ return /******/ (function(modules) { // webpackBootstrap
 /* 0 */
-/***/ function(module, exports, __webpack_require__) {
+/***/ (function(module, exports, __webpack_require__) {
 	'use strict';
@@ -95,7 +95,7 @@ return /******/ (function(modules) { // webpackBootstrap
 	// Each of these augment the Handlebars object. No need to setup here.
 	// (This is done to easily share code between commonjs and browse envs)
-	var _handlebarsSafeString = __webpack_require__(17);
+	var _handlebarsSafeString = __webpack_require__(20);
 	var _handlebarsSafeString2 = _interopRequireDefault(_handlebarsSafeString);
@@ -107,11 +107,11 @@ return /******/ (function(modules) { // webpackBootstrap
 	var Utils = _interopRequireWildcard(_handlebarsUtils);
-	var _handlebarsRuntime = __webpack_require__(18);
+	var _handlebarsRuntime = __webpack_require__(21);
 	var runtime = _interopRequireWildcard(_handlebarsRuntime);
-	var _handlebarsNoConflict = __webpack_require__(19);
+	var _handlebarsNoConflict = __webpack_require__(33);
 	var _handlebarsNoConflict2 = _interopRequireDefault(_handlebarsNoConflict);
@@ -143,9 +143,9 @@ return /******/ (function(modules) { // webpackBootstrap
 	exports['default'] = inst;
 	module.exports = exports['default'];
 /* 1 */
-/***/ function(module, exports) {
+/***/ (function(module, exports) {
 	"use strict";
@@ -168,9 +168,9 @@ return /******/ (function(modules) { // webpackBootstrap
 	exports.__esModule = true;
 /* 2 */
 	"use strict";
@@ -182,9 +182,9 @@ return /******/ (function(modules) { // webpackBootstrap
 /* 3 */
 	'use strict';
@@ -199,15 +199,15 @@ return /******/ (function(modules) { // webpackBootstrap
 	var _exception2 = _interopRequireDefault(_exception);
-	var _helpers = __webpack_require__(6);
+	var _helpers = __webpack_require__(9);
-	var _decorators = __webpack_require__(14);
+	var _decorators = __webpack_require__(17);
-	var _logger = __webpack_require__(16);
+	var _logger = __webpack_require__(19);
 	var _logger2 = _interopRequireDefault(_logger);
-	var VERSION = '4.0.5';
+	var VERSION = '4.0.12';
 	exports.VERSION = VERSION;
 	var COMPILER_REVISION = 7;
@@ -289,9 +289,9 @@ return /******/ (function(modules) { // webpackBootstrap
 	exports.createFrame = _utils.createFrame;
 	exports.logger = _logger2['default'];
 /* 4 */
 	'use strict';
@@ -417,12 +417,14 @@ return /******/ (function(modules) { // webpackBootstrap
 	  return (contextPath ? contextPath + '.' : '') + id;
 /* 5 */
 	'use strict';
+	var _Object$defineProperty = __webpack_require__(6)['default'];
 	var errorProps = ['description', 'fileName', 'lineNumber', 'message', 'name', 'number', 'stack'];
@@ -450,9 +452,23 @@ return /******/ (function(modules) { // webpackBootstrap
 	    Error.captureStackTrace(this, Exception);
-	  if (loc) {
-	    this.lineNumber = line;
-	    this.column = column;
+	  try {
+	    if (loc) {
+	      this.lineNumber = line;
+	      // Work around issue under safari where we can't directly set the column value
+	      /* istanbul ignore next */
+	      if (_Object$defineProperty) {
+	        Object.defineProperty(this, 'column', {
+	          value: column,
+	          enumerable: true
+	      } else {
+	        this.column = column;
+	  } catch (nop) {
+	    /* Ignore if the browser is very particular */
@@ -461,9 +477,42 @@ return /******/ (function(modules) { // webpackBootstrap
 	exports['default'] = Exception;
GitHub sha: c8c84f46
:+1:
