FIX: Use ImageMagick to detect animated images (#11702)
This is a fallback when FastImage cannot be used (animated WEBP images).
diff --git a/lib/upload_creator.rb b/lib/upload_creator.rb
index 9c2f4ab..3d8b0e8 100644
--- a/lib/upload_creator.rb
+++ b/lib/upload_creator.rb
@@ -126,7 +126,7 @@ class UploadCreator
if is_image
@upload.thumbnail_width, @upload.thumbnail_height = ImageSizer.resize(*@image_info.size)
@upload.width, @upload.height = @image_info.size
- @upload.animated = FastImage.animated?(@file)
+ @upload.animated = animated?
add_metadata!
@@ -267,13 +267,13 @@ class UploadCreator
def should_alter_quality?
- return false if FastImage.animated?(@file)
+ return false if animated?
@upload.target_image_quality(@file.path, SiteSetting.recompress_original_jpg_quality).present?
def should_downsize?
- max_image_size > 0 && filesize >= max_image_size && !FastImage.animated?(@file)
+ max_image_size > 0 && filesize >= max_image_size && !animated?
def downsize!
@@ -351,7 +351,7 @@ class UploadCreator
def should_crop?
- return false if ['profile_background', 'card_background', 'custom_emoji'].include?(@opts[:type]) && FastImage.animated?(@file)
+ return false if ['profile_background', 'card_background', 'custom_emoji'].include?(@opts[:type]) && animated?
TYPES_TO_CROP.include?(@opts[:type])
@@ -427,4 +427,30 @@ class UploadCreator
@upload.secure = UploadSecurity.new(@upload, @opts).should_be_secure?
+ private
+ def animated?
+ return @animated if @animated != nil
+ @animated ||= begin
+ is_animated = FastImage.animated?(@file)
+ type = @image_info.type.to_s
+ if is_animated != nil
+ # FastImage will return nil if it cannot determine if animated
+ is_animated
+ elsif type == "gif" || type == "webp"
+ # Only GIFs, WEBPs and a few other unsupported image types can be animated
+ OptimizedImage.ensure_safe_paths!(@file.path)
+ command = ["identify", "-format", "%n\\n", @file.path]
+ frames = Discourse::Utils.execute_command(*command).to_i rescue 1
+ frames > 1
+ else
+ false
+ end
+ end
+ end
diff --git a/spec/fixtures/images/animated.webp b/spec/fixtures/images/animated.webp
new file mode 100644
index 0000000..5b00711
Binary files /dev/null and b/spec/fixtures/images/animated.webp differ
diff --git a/spec/lib/upload_creator_spec.rb b/spec/lib/upload_creator_spec.rb
index 23442bc..2de42a6 100644
--- a/spec/lib/upload_creator_spec.rb
+++ b/spec/lib/upload_creator_spec.rb
@@ -137,6 +137,9 @@ RSpec.describe UploadCreator do
let(:animated_filename) { "animated.gif" }
let(:animated_file) { file_from_fixtures(animated_filename) }
+ let(:animated_webp_filename) { "animated.webp" }
+ let(:animated_webp_file) { file_from_fixtures(animated_webp_filename) }
before do
SiteSetting.png_to_jpg_quality = 1
@@ -208,6 +211,20 @@ RSpec.describe UploadCreator do
expect(File.extname(upload.url)).to eq('.gif')
expect(upload.original_filename).to eq('animated.gif')
+ it 'should not convert animated WEBP images' do
+ expect do
+ UploadCreator.new(animated_webp_file, animated_webp_filename,
+ force_optimize: true
+ ).create_for(user.id)
+ end.to change { Upload.count }.by(1)
+ upload = Upload.last
+ expect(upload.extension).to eq('webp')
+ expect(File.extname(upload.url)).to eq('.webp')
+ expect(upload.original_filename).to eq('animated.webp')
+ end
GitHub sha: 74b95c88
