FIX: use new changed method name and remove whitespaces
diff --git a/app/models/concerns/has_url.rb b/app/models/concerns/has_url.rb
index eca6cf9..fd0c02f 100644
--- a/app/models/concerns/has_url.rb
+++ b/app/models/concerns/has_url.rb
@@ -8,16 +8,16 @@ module HasUrl
     def get_from_url(url)
       return if url.blank?
       uri = begin
         URI(URI.unescape(url))
       rescue URI::Error
       return if uri&.path.blank?
       data = extract_url(uri.path)
       return if data.blank?
       self.find_by("url LIKE ?", "%#{data[1]}")
diff --git a/lib/upload_recovery.rb b/lib/upload_recovery.rb
index 6880c52..4e5bec5 100644
--- a/lib/upload_recovery.rb
+++ b/lib/upload_recovery.rb
@@ -28,7 +28,7 @@ class UploadRecovery
               recover_post_upload(post, Upload.sha1_from_short_url(orig_src))
           elsif url = (media["href"] || media["src"])
-            data = Upload.extract_upload_url(url)
+            data = Upload.extract_url(url)
             next unless data
             sha1 = data[2]
@@ -58,7 +58,7 @@ class UploadRecovery
         background = user_profile.public_send(column)
         if background.present? && !Upload.exists?(url: background)
-          data = Upload.extract_upload_url(background)
+          data = Upload.extract_url(background)
           next unless data
           sha1 = data[2]
diff --git a/spec/models/upload_spec.rb b/spec/models/upload_spec.rb
index 59fa7e4..0cc49e6 100644
--- a/spec/models/upload_spec.rb
+++ b/spec/models/upload_spec.rb
@@ -95,6 +95,14 @@ describe Upload do
     expect(created_upload.valid?).to eq(false)
+  context ".extract_url" do
+    let(:url) { 'https://example.com/uploads/default/original/1X/d1c2d40ab994e8410c.png' }
+    it 'should return the right part of url' do
+      expect(Upload.extract_url(url).to_s).to eq('/original/1X/d1c2d40ab994e8410c.png')
+    end
+  end
   context ".get_from_url" do
     let(:sha1) { "10f73034616a796dfd70177dc54b6def44c4ba6f" }
     let(:upload) { Fabricate(:upload, sha1: sha1) }
GitHub sha: f5ac0125
