FIX: Use previous chunk to check if local backup chunk upload complete (PR #14896)
I thought this was a significant enough fix to split into its own PR. The draft PR I have in progress is the one actually adding the uppy chunked local backup upload.
Uppy and Resumable slice up their chunks differently, which causes a difference in this algorithm. Let’s take a 131.6MB file (137951695 bytes) with a 5MB (5242880 bytes) chunk size. For resumable, there are 26 chunks, and uppy there are 27. This is controlled by forceChunkSize in resumable which is false by default. The final chunk size is 6879695 (chunk size + remainder) whereas in uppy it is 1636815 (just remainder).
This means that the current condition of uploaded_file_size + current_chunk_size >= total_size is hit twice by uppy, because it uses a more correct number of chunks. This can be solved for both uppy and resumable by checking the previous chunk number * chunk_size as the uploaded_file_size.
An example of what is happening before that change, using the current chunk number to calculate uploaded_file_size.
chunk 26: resumable: uploaded_file_size (26 * 5242880) + current_chunk_size (6879695) = 143194575 >= total_size (137951695) ? YES chunk 26: uppy: uploaded_file_size (26 * 5242880) + current_chunk_size (5242880) = 141557760 >= total_size (137951695) ? YES chunk 27: uppy: uploaded_file_size (27 * 5242880) + current_chunk_size (1636815) = 143194575 >= total_size (137951695) ? YES
An example of what this looks like after the change, using the previous chunk number to calculate uploaded_file_size:
chunk 26: resumable: uploaded_file_size (25 * 5242880) + current_chunk_size (6879695) = 137951695 >= total_size (137951695) ? YES chunk 26: uppy: uploaded_file_size (25 * 5242880) + current_chunk_size (5242880) = 136314880 >= total_size (137951695) ? NO chunk 27: uppy: uploaded_file_size (26 * 5242880) + current_chunk_size (1636815) = 137951695 >= total_size (137951695) ? YES
GitHub
This PR looks good I just want to confirm this test is reasonably fast?
Yes, even the one with 3 POST calls is Finished in 0.49878 seconds. It’s just uploading Tempfiles which are 0 bytes.
