FIX: Use the return code from which correctly
The return code of which is the number of arguments which failed… but what we actually want is 0 when at least one of the docker exectutables is found and nonzero when none are found.
diff --git a/discourse-setup b/discourse-setup
index 3548feb..df2d5be 100755
--- a/discourse-setup
+++ b/discourse-setup
@@ -122,14 +122,22 @@ check_IP_match() {
 ## Do we have docker?
-check_and_install_docker () {
-  if ! which docker.io docker 2>/dev/null ; then
-    echo Failed to find docker.io or docker on your PATH.
+check_docker() {
+  (which docker || which docker.io) 2>/dev/null
+  echo $?
+check_and_install_docker() {
+  found_docker=$(check_docker)
+  if [ "$found_docker" -ne 0 ]; then
+    echo Failed to find docker or docker.io on your PATH.
     read -p "Enter to install Docker from https://get.docker.com/ or Ctrl+C to exit"
     curl https://get.docker.com/ | sh
-      echo Still failed to find docker.io or docker on your PATH.
+      echo Still failed to find docker or docker.io on your PATH.
       echo Docker install failed. Quitting.
       exit
     fi
GitHub sha: f568633bf060c18cc0866b4018842ce9ec9da33a
This commit appears in #557 which was approved by Falco. It was merged by Falco.
