FIX: Use the same hljs version in prod and tests (#14913)
It was at ~10.7.0 (7f3240ea) in tests and 10.6.0 (eb122d3b) in production build before… So my #14908 broke the build.
diff --git a/package.json b/package.json
index 7f7f88c..f97e6bb 100644
--- a/package.json
+++ b/package.json
@@ -8,7 +8,7 @@
   "dependencies": {
     "@discourse/itsatrap": "^2.0.10",
     "@fortawesome/fontawesome-free": "5.11.2",
-    "@highlightjs/cdn-assets": "^10.6.0",
+    "@highlightjs/cdn-assets": "^10.7.0",
     "@json-editor/json-editor": "^2.5.2",
     "@popperjs/core": "v2.9.3",
     "@uppy/aws-s3": "^2.0.4",
diff --git a/vendor/assets/javascripts/highlightjs/README.md b/vendor/assets/javascripts/highlightjs/README.md
index 0a70f62..30d84b9 100644
--- a/vendor/assets/javascripts/highlightjs/README.md
+++ b/vendor/assets/javascripts/highlightjs/README.md
@@ -22,7 +22,7 @@ markup, doesn’t depend on any framework, and has automatic language
 detection.
 If you'd like to read the full README:<br>
-<https://github.com/highlightjs/highlight.js/blob/master/README.md>
+<https://github.com/highlightjs/highlight.js/blob/main/README.md>
 ## License
@@ -38,8 +38,8 @@ The Github project may be found at: <https://github.com/highlightjs/highlight.js
 Further in-depth documentation for the API and other topics is at
 <http://highlightjs.readthedocs.io/>.
-Authors and contributors are listed in the [AUTHORS.txt][8] file.
+A list of the Core Team and contributors can be found in the [CONTRIBUTORS.md][8] file.
 [1]: https://www.npmjs.com/package/highlight.js
-[7]: https://github.com/highlightjs/highlight.js/blob/master/LICENSE
-[8]: https://github.com/highlightjs/highlight.js/blob/master/AUTHORS.txt
+[7]: https://github.com/highlightjs/highlight.js/blob/main/LICENSE
+[8]: https://github.com/highlightjs/highlight.js/blob/main/CONTRIBUTORS.md
diff --git a/vendor/assets/javascripts/highlightjs/highlight-test-bundle.min.js b/vendor/assets/javascripts/highlightjs/highlight-test-bundle.min.js
index 0586d30..8306646 100644
--- a/vendor/assets/javascripts/highlightjs/highlight-test-bundle.min.js
+++ b/vendor/assets/javascripts/highlightjs/highlight-test-bundle.min.js
@@ -1,5 +1,5 @@
-  Highlight.js 10.6.0 (7f3240ea)
+  Highlight.js 10.7.3 (0c4cc8a1)
   License: BSD-3-Clause
   Copyright (c) 2006-2021, Ivan Sagalaev
@@ -9,16 +9,17 @@ throw Error("map is read-only")}:t instanceof Set&&(t.add=t.clear=t.delete=()=>{
 throw Error("set is read-only")
 }),Object.freeze(t),Object.getOwnPropertyNames(t).forEach((n=>{var i=t[n]
 ;"object"!=typeof i||Object.isFrozen(i)||e(i)})),t}var t=e,n=e;t.default=n
-;class i{constructor(e){void 0===e.data&&(e.data={}),this.data=e.data}
-ignoreMatch(){this.ignore=!0}}function r(e){
+;class i{constructor(e){
+void 0===e.data&&(e.data={}),this.data=e.data,this.isMatchIgnored=!1}
+ignoreMatch(){this.isMatchIgnored=!0}}function s(e){
 return e.replace(/&/g,"&amp;").replace(/</g,"&lt;").replace(/>/g,"&gt;").replace(/"/g,"&quot;").replace(/'/g,"&#x27;")
-}function s(e,...t){const n=Object.create(null);for(const t in e)n[t]=e[t]
-;return t.forEach((e=>{for(const t in e)n[t]=e[t]})),n}const a=e=>!!e.kind
+}function a(e,...t){const n=Object.create(null);for(const t in e)n[t]=e[t]
+;return t.forEach((e=>{for(const t in e)n[t]=e[t]})),n}const r=e=>!!e.kind
 ;class l{constructor(e,t){
 this.buffer="",this.classPrefix=t.classPrefix,e.walk(this)}addText(e){
-this.buffer+=r(e)}openNode(e){if(!a(e))return;let t=e.kind
+this.buffer+=s(e)}openNode(e){if(!r(e))return;let t=e.kind
 ;e.sublanguage||(t=`${this.classPrefix}${t}`),this.span(t)}closeNode(e){
-a(e)&&(this.buffer+="</span>")}value(){return this.buffer}span(e){
+r(e)&&(this.buffer+="</span>")}value(){return this.buffer}span(e){
 this.buffer+=`<span class="${e}">`}}class o{constructor(){this.rootNode={
 children:[]},this.stack=[this.rootNode]}get top(){
 return this.stack[this.stack.length-1]}get root(){return this.rootNode}add(e){
@@ -36,21 +37,21 @@ addText(e){""!==e&&this.add(e)}addSublanguage(e,t){const n=e.root
 ;n.kind=t,n.sublanguage=!0,this.add(n)}toHTML(){
 return new l(this,this.options).value()}finalize(){return!0}}function g(e){
 return e?"string"==typeof e?e:e.source:null}
-const u=/\[(?:[^\\\]]|\\.)*\]|\(\??|\\([1-9][0-9]*)|\\./,d="[a-zA-Z]\\w*",h="[a-zA-Z_]\\w*",f="\\b\\d+(\\.\\d+)?",p="(-?)(\\b0[xX][a-fA-F0-9]+|(\\b\\d+(\\.\\d*)?|\\.\\d+)([eE][-+]?\\d+)?)",m="\\b(0b[01]+)",b={
+const u=/\[(?:[^\\\]]|\\.)*\]|\(\??|\\([1-9][0-9]*)|\\./,h="[a-zA-Z]\\w*",d="[a-zA-Z_]\\w*",f="\\b\\d+(\\.\\d+)?",p="(-?)(\\b0[xX][a-fA-F0-9]+|(\\b\\d+(\\.\\d*)?|\\.\\d+)([eE][-+]?\\d+)?)",m="\\b(0b[01]+)",b={
 begin:"\\\\[\\s\\S]",relevance:0},E={className:"string",begin:"'",end:"'",
 illegal:"\\n",contains:[b]},x={className:"string",begin:'"',end:'"',
 illegal:"\\n",contains:[b]},v={
 begin:/\b(a|an|the|are|I'm|isn't|don't|doesn't|won't|but|just|should|pretty|simply|enough|gonna|going|wtf|so|such|will|you|your|they|like|more)\b/
-},w=(e,t,n={})=>{const i=s({className:"comment",begin:e,end:t,contains:[]},n)
+},w=(e,t,n={})=>{const i=a({className:"comment",begin:e,end:t,contains:[]},n)
 ;return i.contains.push(v),i.contains.push({className:"doctag",
 begin:"(?:TODO|FIXME|NOTE|BUG|OPTIMIZE|HACK|XXX):",relevance:0}),i
 },y=w("//","$"),N=w("/\\*","\\*/"),R=w("#","$");var _=Object.freeze({
-__proto__:null,MATCH_NOTHING_RE:/\b\B/,IDENT_RE:d,UNDERSCORE_IDENT_RE:h,
+__proto__:null,MATCH_NOTHING_RE:/\b\B/,IDENT_RE:h,UNDERSCORE_IDENT_RE:d,
 NUMBER_RE:f,C_NUMBER_RE:p,BINARY_NUMBER_RE:m,
 RE_STARTERS_RE:"!|!=|!==|%|%=|&|&&|&=|\\*|\\*=|\\+|\\+=|,|-|-=|/=|/|:|;|<<|<<=|<=|<|===|==|=|>>>=|>>=|>=|>>>|>>|>|\\?|\\[|\\{|\\(|\\^|\\^=|\\||\\|=|\\|\\||~",
 SHEBANG:(e={})=>{const t=/^#![ ]*\//
 ;return e.binary&&(e.begin=((...e)=>e.map((e=>g(e))).join(""))(t,/.*\b/,e.binary,/\b.*/)),
-s({className:"meta",begin:t,end:/$/,relevance:0,"on:begin":(e,t)=>{
+a({className:"meta",begin:t,end:/$/,relevance:0,"on:begin":(e,t)=>{
 0!==e.index&&t.ignoreMatch()}},e)},BACKSLASH_ESCAPE:b,APOS_STRING_MODE:E,
 QUOTE_STRING_MODE:x,PHRASAL_WORDS_MODE:v,COMMENT:w,C_LINE_COMMENT_MODE:y,
 C_BLOCK_COMMENT_MODE:N,HASH_COMMENT_MODE:R,NUMBER_MODE:{className:"number",
@@ -60,27 +61,27 @@ className:"number",
 begin:f+"(%|em|ex|ch|rem|vw|vh|vmin|vmax|cm|mm|in|pt|pc|px|deg|grad|rad|turn|s|ms|Hz|kHz|dpi|dpcm|dppx)?",
 relevance:0},REGEXP_MODE:{begin:/(?=\/[^/\n]*\/)/,contains:[{className:"regexp",
 begin:/\//,end:/\/[gimuy]*/,illegal:/\n/,contains:[b,{begin:/\[/,end:/\]/,
-relevance:0,contains:[b]}]}]},TITLE_MODE:{className:"title",begin:d,relevance:0
-},UNDERSCORE_TITLE_MODE:{className:"title",begin:h,relevance:0},METHOD_GUARD:{
+relevance:0,contains:[b]}]}]},TITLE_MODE:{className:"title",begin:h,relevance:0
+},UNDERSCORE_TITLE_MODE:{className:"title",begin:d,relevance:0},METHOD_GUARD:{
 begin:"\\.\\s*[a-zA-Z_]\\w*",relevance:0},END_SAME_AS_BEGIN:e=>Object.assign(e,{
 "on:begin":(e,t)=>{t.data._beginMatch=e[1]},"on:end":(e,t)=>{
 t.data._beginMatch!==e[1]&&t.ignoreMatch()}})});function k(e,t){
-"."===e.input[e.index-1]&&t.ignoreMatch()}function O(e,t){
+"."===e.input[e.index-1]&&t.ignoreMatch()}function M(e,t){
 t&&e.beginKeywords&&(e.begin="\\b("+e.beginKeywords.split(" ").join("|")+")(?!\\.)(?=\\b|\\s)",
 e.__beforeBegin=k,e.keywords=e.keywords||e.beginKeywords,delete e.beginKeywords,
-void 0===e.relevance&&(e.relevance=0))}function M(e,t){
+void 0===e.relevance&&(e.relevance=0))}function O(e,t){
 Array.isArray(e.illegal)&&(e.illegal=((...e)=>"("+e.map((e=>g(e))).join("|")+")")(...e.illegal))
 }function A(e,t){if(e.match){
 if(e.begin||e.end)throw Error("begin & end are not supported with match")
 ;e.begin=e.match,delete e.match}}function L(e,t){
 void 0===e.relevance&&(e.relevance=1)}
-const j=["of","and","for","in","not","or","if","then","parent","list","value"]
-;function B(e,t,n="keyword"){const i={}
-;return"string"==typeof e?r(n,e.split(" ")):Array.isArray(e)?r(n,e):Object.keys(e).forEach((n=>{
-Object.assign(i,B(e[n],t,n))})),i;function r(e,n){
+const I=["of","and","for","in","not","or","if","then","parent","list","value"]
+;function j(e,t,n="keyword"){const i={}
GitHub sha: 904275a8f1a41ed356380e11ed1c28b8ad312030
This commit appears in #14913 which was approved by blake. It was merged by CvX.
