FIX: Use updated routes to link user profiles (PR #60)
This fixes links for both, the user view:
and the query view:
GitHub
Does this work when using subfolder?
Are you asking if the fix works or the route? The route works as you can see on Profile - system - LiveChat Community - a place connecting users, experts and developers.
Sure, but I don’t think that URL is the right one when using a subfolder. It’s missing the baseUri like in the raw hbs file.
I tested this on a subfolder site and both of these links lead to https://www.example.com/forum/users/system/activity. When I manually change the users to u in the url, the link then works without any other changes. So I think the sub-folder part before the suffix is wired up correctly.
Does that sound right?
