FIX: Users can remove themselves from a PM even if they can still access it through a group. (#11693)
If a group you’re a member of is invited to a PM, you can no longer remove yourself from it. This means you won’t be able to remove the message from your inbox, and even if you archive it, it’ll come back once someone replies.
diff --git a/app/serializers/topic_view_details_serializer.rb b/app/serializers/topic_view_details_serializer.rb
index 16a28e4..2576bf7 100644
--- a/app/serializers/topic_view_details_serializer.rb
+++ b/app/serializers/topic_view_details_serializer.rb
@@ -163,7 +163,9 @@ class TopicViewDetailsSerializer < ApplicationSerializer
def allowed_users
- object.topic.allowed_users.reject { |user| object.group_allowed_user_ids.include?(user.id) }
+ object.topic.allowed_users.reject do |user|
+ object.group_allowed_user_ids.include?(user.id) && user != scope.user
+ end
def include_allowed_users?
diff --git a/spec/serializers/topic_view_details_serializer_spec.rb b/spec/serializers/topic_view_details_serializer_spec.rb
new file mode 100644
index 0000000..0705ee4
--- /dev/null
+++ b/spec/serializers/topic_view_details_serializer_spec.rb
@@ -0,0 +1,29 @@
+require 'rails_helper'
+describe TopicViewDetailsSerializer do
+ describe '#allowed_users' do
+ it "add the current user to the allowed user's list even if they are an allowed group member" do
+ participant = Fabricate(:user)
+ another_participant = Fabricate(:user)
+ participant_group = Fabricate(:group)
+ participant_group.add(participant)
+ participant_group.add(another_participant)
+ pm = Fabricate(:private_message_topic,
+ topic_allowed_users: [
+ Fabricate.build(:topic_allowed_user, user: participant),
+ Fabricate.build(:topic_allowed_user, user: another_participant)
+ topic_allowed_groups: [Fabricate.build(:topic_allowed_group, group: participant_group)]
+ serializer = described_class.new(TopicView.new(pm, participant), scope: Guardian.new(participant))
+ allowed_users = serializer.as_json.dig(:topic_view_details, :allowed_users).map { |u| u[:id] }
+ expect(allowed_users).to contain_exactly(participant.id)
+ end
+ end
+end
GitHub sha: e52ccaa5
