FIX: Users should able check the emails for self
diff --git a/app/controllers/users_controller.rb b/app/controllers/users_controller.rb
index fe87d7d..5d7c99b 100644
--- a/app/controllers/users_controller.rb
+++ b/app/controllers/users_controller.rb
@@ -148,9 +148,11 @@ class UsersController < ApplicationController
   def check_emails
     user = fetch_user_from_params(include_inactive: true)
-    guardian.ensure_can_check_emails!(user)
-    StaffActionLogger.new(current_user).log_check_email(user, context: params[:context])
+    unless user == current_user
+      guardian.ensure_can_check_emails!(user)
+      StaffActionLogger.new(current_user).log_check_email(user, context: params[:context])
+    end
     email, *secondary_emails = user.emails
diff --git a/spec/requests/users_controller_spec.rb b/spec/requests/users_controller_spec.rb
index 6752147..11dda38 100644
--- a/spec/requests/users_controller_spec.rb
+++ b/spec/requests/users_controller_spec.rb
@@ -2072,6 +2072,19 @@ describe UsersController do
         expect(response).to be_forbidden
+      it "returns emails and associated_accounts for self" do
+        user = Fabricate(:user)
+        sign_in(user)
+        get "/u/#{user.username}/emails.json"
+        expect(response.status).to eq(200)
+        json = JSON.parse(response.body)
+        expect(json["email"]).to eq(user.email)
+        expect(json["secondary_emails"]).to eq(user.secondary_emails)
+        expect(json["associated_accounts"]).to eq([])
+      end
       it "returns emails and associated_accounts when you're allowed to see them" do
         sign_in_admin
GitHub sha: e7821a63
I’m curious why this was required? The user email should be included in the current user serializer.
api.getCurrentUser().findDetails().then(user => {
  console.log(user.get("email"))
Associated accounts should be there as well.
No, current user serializer doesn’t have these values since it inherits the BasicUserSerializer. Maybe we should include the emails in current user serializer too.
Sorry, I meant “The user serializer for the current user”, rather than “CurrentUserSerializer”. Email and associated accounts are included there, because we display them in the user preferences.
Yes, currentUser.findDetails() method working fine. But it also demands a network request (/u/USERNAME.json) to get email field value same like currentUser.checkEmail(). That’s why I used it in theme code and later realized that it won’t work for non-staff users. Anyway in API perspective it should be possible to check emails and I shouldn’t get logged for my own email checks right?
check-email
I am able to understand your concern. Previously checkEmail method was only allowed for staffs. If it’s not good for security then I will revert the commit and will use findDetails method instead.
Ah I see, so the checkEmail response is going to be slightly smaller/faster than than the findDetails response :+1:
It is no problem for security - the change looks good to me, and I agree there is no need to log checking your own email. Thanks for explaining :heart:
