FIX: uses simpler patternj for custom href on extra nav items (PR #8015)
THe main advantage of this solution is that it will be called on each rerendered whereas the other is not once href has been set.
Example API:
      api.addNavigationBarItem({
        displayName: "Foo",
        customHref: function(category, args) {
          const router = api.container.lookup("service:router");
          const queryParams = { bar: "1" };
          return router.urlFor(router.currentRouteName, category, {
            queryParams
GitHub
You’ve signed the CLA, jjaffeux. Thank you! This pull request is ready for review.
Cool, I say we try this out!
