FIX: validate Invite email against `EmailValidator.email_regex` (#6975)
FIX: validate Invite email against EmailValidator.email_regex (#6975)
diff --git a/app/models/invite.rb b/app/models/invite.rb
index 2a7f968..b201240 100644
--- a/app/models/invite.rb
+++ b/app/models/invite.rb
@@ -16,7 +16,7 @@ class Invite < ActiveRecord::Base
   has_many :topic_invites
   has_many :topics, through: :topic_invites, source: :topic
   validates_presence_of :invited_by_id
-  validates :email, email: true
+  validates :email, email: true, format: { with: EmailValidator.email_regex }
   before_create do
     self.invite_key ||= SecureRandom.hex
diff --git a/spec/models/invite_spec.rb b/spec/models/invite_spec.rb
index 6ed73ee..15ebea3 100644
--- a/spec/models/invite_spec.rb
+++ b/spec/models/invite_spec.rb
@@ -25,9 +25,15 @@ describe Invite do
   context 'email validators' do
     let(:coding_horror) { Fabricate(:coding_horror) }
-    let(:invite) { Invite.create(email: "test@mailinator.com", invited_by: coding_horror) }
+    it "should not allow an invite with unformatted email address" do
+      expect {
+        Fabricate(:invite, email: "John Doe <john.doe@example.com>")
+      }.to raise_error(ActiveRecord::RecordInvalid)
+    end
     it "should not allow an invite with blacklisted email" do
+      invite = Invite.create(email: "test@mailinator.com", invited_by: coding_horror)
       expect(invite).not_to be_valid
diff --git a/spec/requests/invites_controller_spec.rb b/spec/requests/invites_controller_spec.rb
index b2b7f41..9da4714 100644
--- a/spec/requests/invites_controller_spec.rb
+++ b/spec/requests/invites_controller_spec.rb
@@ -214,8 +214,9 @@ describe InvitesController do
     context 'with an invalid invite record' do
-      let(:invite) { Fabricate(:invite, email: "John Doe <john.doe@example.com>") }
+      let(:invite) { Fabricate(:invite) }
       it "responds with error message" do
+        invite.update_attribute(:email, "John Doe <john.doe@example.com>")
         put "/invites/show/#{invite.invite_key}.json"
         expect(response.status).to eq(200)
         json = JSON.parse(response.body)
GitHub sha: ab2c2ea6
