FIX: Various translation string fixes (#13715)
Make small action post description a correct sentence. Replace true and false in site settings description with enabled and disabled.
diff --git a/app/assets/javascripts/discourse/app/lib/formatter.js b/app/assets/javascripts/discourse/app/lib/formatter.js
index 850da25..22b1b7f 100644
--- a/app/assets/javascripts/discourse/app/lib/formatter.js
+++ b/app/assets/javascripts/discourse/app/lib/formatter.js
@@ -108,6 +108,10 @@ function wrapAgo(dateStr) {
   return I18n.t("dates.wrap_ago", { date: dateStr });
+function wrapOn(dateStr) {
+  return I18n.t("dates.wrap_on", { date: dateStr });
 export function durationTiny(distance, ageOpts) {
   if (typeof distance !== "number") {
     return "—";
@@ -288,6 +292,9 @@ function relativeAgeMedium(date, options) {
     displayDate = I18n.t("now");
   } else if (distance > fiveDaysAgo) {
     displayDate = smartShortDate(date, shortDate);
+    if (options.wrapOn) {
+      displayDate = wrapOn(displayDate);
   } else {
     displayDate = relativeAgeMediumSpan(distance, leaveAgo);
@@ -318,6 +325,11 @@ export function relativeAge(date, options) {
       date,
       Object.assign(options, { format: "medium", leaveAgo: true })
+  } else if (format === "medium-with-ago-and-on") {
+    return relativeAgeMedium(
+      date,
+      Object.assign(options, { format: "medium", leaveAgo: true, wrapOn: true })
   return "UNKNOWN FORMAT";
diff --git a/app/assets/javascripts/discourse/app/widgets/post-small-action.js b/app/assets/javascripts/discourse/app/widgets/post-small-action.js
index be5066e..7607550 100644
--- a/app/assets/javascripts/discourse/app/widgets/post-small-action.js
+++ b/app/assets/javascripts/discourse/app/widgets/post-small-action.js
@@ -10,7 +10,9 @@ import { userPath } from "discourse/lib/url";
 export function actionDescriptionHtml(actionCode, createdAt, username) {
   const dt = new Date(createdAt);
-  const when = autoUpdatingRelativeAge(dt, { format: "medium-with-ago" });
+  const when = autoUpdatingRelativeAge(dt, {
+    format: "medium-with-ago-and-on",
   let who = "";
   if (username) {
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index 1b5c96f..ff09213 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -53,6 +53,7 @@ en:
       long_date_with_year_with_linebreak: "MMM D, 'YY <br/>LT"
       wrap_ago: "%{date} ago"
+      wrap_on: "on %{date}"
       tiny:
         half_a_minute: "< 1m"
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index df4db6a..e8a0a75 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1492,7 +1492,7 @@ en:
     category_search_priority_high_weight: "Weight applied to ranking for high category search priority."
     allow_uncategorized_topics: "Allow topics to be created without a category. WARNING: If there are any uncategorized topics, you must recategorize them before turning this off."
     allow_duplicate_topic_titles: "Allow topics with identical, duplicate titles."
-    allow_duplicate_topic_titles_category: "Allow topics with identical, duplicate titles if the category is different. allow_duplicate_topic_titles must be false."
+    allow_duplicate_topic_titles_category: "Allow topics with identical, duplicate titles if the category is different. allow_duplicate_topic_titles must be disabled."
     unique_posts_mins: "How many minutes before a user can make a post with the same content again"
     educate_until_posts: "When the user starts typing their first (n) new posts, show the pop-up new user education panel in the composer."
     title: "The name of this site, as used in the title tag."
@@ -1735,7 +1735,7 @@ en:
     discord_trusted_guilds: 'Only allow members of these Discord guilds to log in via Discord. Use the numeric ID for the guild. For more information, check the instructions <a href="https://meta.discourse.org/t/configuring-discord-login-for-discourse/127129">here</a>. Leave blank to allow any guild.'
     enable_backups: "Allow administrators to create backups of the forum"
-    allow_restore: "Allow restore, which can replace ALL site data! Leave false unless you plan to restore a backup"
+    allow_restore: "Allow restore, which can replace ALL site data! Leave disabled unless you plan to restore a backup"
     maximum_backups: "The maximum amount of backups to keep on disk. Older backups are automatically deleted"
     automatic_backups_enabled: "Run automatic backups as defined in backup frequency"
     backup_frequency: "The number of days between backups."
GitHub sha: 21cf1b78daf56c4bdcfc5b092bccb9bc6cf632f3
This commit appears in #13715 which was approved by gschlager. It was merged by nbianca.
