FIX: We don't want to double-process flagged posts. (#62)
FIX: We don’t want to double-process flagged posts. (#62)
There’s a chance a TL3 user flags a TL0 post as spam before Akismet has a chance of processing it. If it happens, only a flagged post approved by the system will appear in the queue. Staff won’t be able to restore it from the queue because Akismet already deleted it (should be hidden instead).
diff --git a/jobs/regular/check_akismet_post.rb b/jobs/regular/check_akismet_post.rb
index 3b0f5e8..0b5e06c 100644
--- a/jobs/regular/check_akismet_post.rb
+++ b/jobs/regular/check_akismet_post.rb
@@ -10,7 +10,7 @@ module Jobs
       return unless post = Post.find_by(id: args[:post_id], user_deleted: false)
-      return if ReviewableQueuedPost.exists?(target: post)
+      return if Reviewable.exists?(target: post)
       client = Akismet::Client.build_client
       DiscourseAkismet::PostsBouncer.new.perform_check(client, post)
diff --git a/lib/discourse_akismet/posts_bouncer.rb b/lib/discourse_akismet/posts_bouncer.rb
index e0223d6..038bf71 100644
--- a/lib/discourse_akismet/posts_bouncer.rb
+++ b/lib/discourse_akismet/posts_bouncer.rb
@@ -17,7 +17,7 @@ module DiscourseAkismet
         .where('posts.id IS NOT NULL')
         .where('topics.id IS NOT NULL')
         .joins('LEFT OUTER JOIN reviewables ON reviewables.target_id = post_custom_fields.post_id')
-        .where('reviewables.target_type IS NULL OR reviewables.type <> ?', ReviewableQueuedPost.name)
+        .where('reviewables.id IS NULL')
         .includes(post: :topic)
         .references(:post, :topic)
diff --git a/spec/jobs/regular/check_akismet_post_spec.rb b/spec/jobs/regular/check_akismet_post_spec.rb
index 61952f1..0c12f4d 100644
--- a/spec/jobs/regular/check_akismet_post_spec.rb
+++ b/spec/jobs/regular/check_akismet_post_spec.rb
@@ -16,6 +16,14 @@ RSpec.describe Jobs::CheckAkismetPost do
       expect(ReviewableAkismetPost.count).to be_zero
+    it 'does not create a reviewable when a reviewable flagged post already exists for that target' do
+      ReviewableFlaggedPost.needs_review!(target: post, created_by: Discourse.system_user)
+      subject.execute(post_id: post.id)
+      expect(ReviewableAkismetPost.count).to be_zero
+    end
     it 'does not create a reviewable when the post is not spam' do
       Akismet::Client.any_instance.stubs(:comment_check).returns(false)
diff --git a/spec/lib/posts_bouncer_spec.rb b/spec/lib/posts_bouncer_spec.rb
index 23aabcd..6a6f844 100644
--- a/spec/lib/posts_bouncer_spec.rb
+++ b/spec/lib/posts_bouncer_spec.rb
@@ -203,6 +203,13 @@ describe DiscourseAkismet::PostsBouncer do
       expect(described_class.to_check).to be_empty
+    it 'does not retrieve posts that already had another reviewable flagged post' do
+      subject.move_to_state(post, 'new')
+      expect(described_class.to_check).to be_empty
+    end
   describe "#should_check?" do
GitHub sha: aa2540e9
This commit appears in #62 which was approved by eviltrout and riking. It was merged by romanrizzi.
