FIX: We should check for watched words first even if the user is a fast typer. (#10630)
diff --git a/lib/new_post_manager.rb b/lib/new_post_manager.rb
index 3f2f63e..3c4614d 100644
--- a/lib/new_post_manager.rb
+++ b/lib/new_post_manager.rb
@@ -98,12 +98,12 @@ class NewPostManager
       user.trust_level < SiteSetting.approve_new_topics_unless_trust_level.to_i
+    return :watched_word if WordWatcher.new("#{manager.args[:title]} #{manager.args[:raw]}").requires_approval?
     return :fast_typer if is_fast_typer?(manager)
     return :auto_silence_regex if matches_auto_silence_regex?(manager)
-    return :watched_word if WordWatcher.new("#{manager.args[:title]} #{manager.args[:raw]}").requires_approval?
     return :staged if SiteSetting.approve_unless_staged? && user.staged?
     return :category if post_needs_approval_in_its_category?(manager)
diff --git a/spec/components/new_post_manager_spec.rb b/spec/components/new_post_manager_spec.rb
index 65cbe56..847db93 100644
--- a/spec/components/new_post_manager_spec.rb
+++ b/spec/components/new_post_manager_spec.rb
@@ -209,7 +209,6 @@ describe NewPostManager do
     context 'with a fast typer' do
-      let(:manager) { NewPostManager.new(topic.user, raw: 'this is new post content', topic_id: topic.id, first_post_checks: true) }
       let(:user) { manager.user }
       before do
@@ -217,12 +216,27 @@ describe NewPostManager do
       it "adds the silence reason in the system locale" do
+        manager = build_manager_with('this is new post content')
         I18n.with_locale(:fr) do # Simulate french user
           result = NewPostManager.default_handler(manager)
         expect(user.silenced?).to eq(true)
         expect(user.silence_reason).to eq(I18n.t("user.new_user_typed_too_fast", locale: :en))
+      it 'runs the watched words check before checking if the user is a fast typer' do
+        Fabricate(:watched_word, word: "darn", action: WatchedWord.actions[:require_approval])
+        manager = build_manager_with('this is darn new post content')
+        result = NewPostManager.default_handler(manager)
+        expect(result.action).to eq(:enqueued)
+        expect(result.reason).to eq(:watched_word)
+      end
+      def build_manager_with(raw)
+        NewPostManager.new(topic.user, raw: raw, topic_id: topic.id, first_post_checks: true)
+      end
GitHub sha: cac64a95
This commit appears in #10630 which was approved by eviltrout. It was merged by romanrizzi.
