[FIX] Webauthn security key fixes after real-world usage (PR #8135)
Fixes for initial round of QA/real-world usage outlined in Webauthn support - feature - Discourse Meta
  • Fix security key 2FA not working in the mobile login view
  • Bring the password confirmation & reset password link UI for the second factor preferences area of the profile into line with other UI elements in the app
  • Change copy from Disable when removing security keys to Delete
  • Improve error message copy when a user attempts to register a security key they already have registered (“borrowing” Chrome’s excellent copy here)
GitHub
You’ve signed the CLA, mjrbrennan. Thank you! This pull request is ready for review.
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/webauthn-support/126454/19
I believe d-button already has btn as a class.
            <a href class="instructions" {{action "resetPassword"}}>{{i18n 'user.second_factor.forgot_password'}}</a>
I’m going to merge this in, so mobile login isn’t broken; other code suggestions here are pretty trivial. Thanks @mjrbrennan !
