FIX: when updating timestamps on topic set a correct bump date (#13746)
There was a bug with changing timestamps using the topic wrench button. Under some circumstances, a topic was disappearing from the top of the latest tab after changing timestamps. Steps to reproduce:
  • Choose a topic on the latest tab (the topic should be created some time ago, but has recent posts)
  • Change topic timestamps (for example, move them one day forward):
  • Go back to the latest tab and see that topic has disappeared.
This PR fixes this. We were setting topic.bumped_at to the timestamp user specified on the modal. This is incorrect. Instead, we should be setting topic.bumped_at to the created_at timestamp of the last regular (not a whisper and so on) post on the topic.
diff --git a/app/services/topic_timestamp_changer.rb b/app/services/topic_timestamp_changer.rb
index d02cda9..a8d5059 100644
--- a/app/services/topic_timestamp_changer.rb
+++ b/app/services/topic_timestamp_changer.rb
@@ -29,6 +29,7 @@ class TopicTimestampChanger
+      @topic.reset_bumped_at
       update_topic(last_posted_at)
       yield(@topic) if block_given?
@@ -48,7 +49,6 @@ class TopicTimestampChanger
     @topic.update(
       created_at: @timestamp,
       updated_at: @timestamp,
-      bumped_at: @timestamp,
       last_posted_at: last_posted_at
diff --git a/spec/services/topic_timestamp_changer_spec.rb b/spec/services/topic_timestamp_changer_spec.rb
index c94cecf..255530f 100644
--- a/spec/services/topic_timestamp_changer_spec.rb
+++ b/spec/services/topic_timestamp_changer_spec.rb
@@ -26,19 +26,20 @@ describe TopicTimestampChanger do
         TopicTimestampChanger.new(topic: topic, timestamp: new_timestamp.to_f).change!
         topic.reload
+        p1.reload
+        p2.reload
+        last_post_created_at = p2.created_at
         expect(topic.created_at).to eq_time(new_timestamp)
         expect(topic.updated_at).to eq_time(new_timestamp)
-        expect(topic.bumped_at).to eq_time(new_timestamp)
+        expect(topic.bumped_at).to eq_time(last_post_created_at)
+        expect(topic.last_posted_at).to eq_time(last_post_created_at)
-        p1.reload
         expect(p1.created_at).to eq_time(new_timestamp)
         expect(p1.updated_at).to eq_time(new_timestamp)
-        p2.reload
         expect(p2.created_at).to eq_time(new_timestamp + 1.day)
         expect(p2.updated_at).to eq_time(new_timestamp + 1.day)
-        expect(topic.last_posted_at).to eq_time(p2.reload.created_at)
       describe 'when posts have timestamps in the future' do
GitHub sha: c4d7545f356582d280ffeba2637b15392ad21fa0
This commit appears in #13746 which was approved by eviltrout. It was merged by AndrewPrigorshnev.
