Fix/wikipedia oneboxing with url encoded hash (PR #14015)
From the report Wikipedia oneboxing with url encoded section hash
Sections with unreserverd characters will appear url-encoded and need to be unescaped before using it.
Wikipedia generates 2 different spans in this case in the same page, one with an id resulting of replacing the % symbols with . and the other with the decoded version of the string. For example, for /wiki/foo#A%C3%A1A it will generate:
<span id="A.C3.A1A"></span>
<span id="AáA">AáA</span>
Unescaping the m_url_hash_name should work in all cases to target the proper section span.
This PR includes:
  • 1 new test for a url with hash section using the old fixture that was not previously covered
  • 1 new test for a url with a percent-encoded hash section and a new fixture using the reporter’s example
  • Possible fix
First time here… giving Ruby and Rails a try and not entirely sure about conventions (code and commit-wise) in the project, so please, let me know if this needs amending in any way!
Thanks!
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
Thanks, this looks good!
