FIX: word boundary regex (\b) not working in Unicode languages. (PR #9163)
Removed the jQuery Highlight plugin and created a new es6 highlighting library.
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
Can we use Node.ELEMENT_NODE and other enums rather than hard coding integers here? It’s much more clear.
Let’s remove this constant too.
  if (!words.length) return node;
The highlight-html lib should be tested :wink:
@vinothkannans are we just waiting on a few tests here prior to merging? Agree it makes sense to test this, especially since it is so easy to test.
Yes, I’ll make it today :+1:
I did some improvements and added a test here @ZogStriP. The highlight function is performing well in big paragraphs and the large number of posts @SamSaffron. Anyway, we’re going keep using \b regex if Unicode words are not found.
