FIX: wrong file used when updating lodash (#7564)
diff --git a/lodash.custom.js b/lodash.custom.js
deleted file mode 100644
index 373ae5e..0000000
--- a/lodash.custom.js
+++ /dev/null
@@ -1,7853 +0,0 @@
- * @license
- * Lodash (Custom Build) <https://lodash.com/>
- * Build: `lodash include="each,filter,map,range,first,isEmpty,chain,extend,every,omit,merge,union,sortBy,uniq,intersection,reject,compact,reduce,debounce,throttle,values,pick,keys,flatten,min,max,isArray,delay,isString,isEqual,without,invoke,clone,findIndex" minus="template" -d`
- * Copyright JS Foundation and other contributors <https://js.foundation/>
- * Released under MIT license <https://lodash.com/license>
- * Based on Underscore.js 1.8.3 <http://underscorejs.org/LICENSE>
- * Copyright Jeremy Ashkenas, DocumentCloud and Investigative Reporters & Editors
-;(function() {
-  /** Used as a safe reference for `undefined` in pre-ES5 environments. */
-  var undefined;
-  /** Used as the semantic version number. */
-  var VERSION = '4.17.5';
-  /** Used as the size to enable large array optimizations. */
-  var LARGE_ARRAY_SIZE = 200;
-  /** Error message constants. */
-  var FUNC_ERROR_TEXT = 'Expected a function';
-  /** Used to stand-in for `undefined` hash values. */
-  var HASH_UNDEFINED = '__lodash_hash_undefined__';
-  /** Used as the maximum memoize cache size. */
-  var MAX_MEMOIZE_SIZE = 500;
-  /** Used as the internal argument placeholder. */
-  var PLACEHOLDER = '__lodash_placeholder__';
-  /** Used to compose bitmasks for cloning. */
-  var CLONE_DEEP_FLAG = 1,
-      CLONE_FLAT_FLAG = 2,
-      CLONE_SYMBOLS_FLAG = 4;
-  /** Used to compose bitmasks for value comparisons. */
-  var COMPARE_PARTIAL_FLAG = 1,
-      COMPARE_UNORDERED_FLAG = 2;
-  /** Used to compose bitmasks for function metadata. */
-  var WRAP_BIND_FLAG = 1,
-      WRAP_BIND_KEY_FLAG = 2,
-      WRAP_CURRY_BOUND_FLAG = 4,
-      WRAP_CURRY_FLAG = 8,
-      WRAP_CURRY_RIGHT_FLAG = 16,
-      WRAP_PARTIAL_FLAG = 32,
-      WRAP_PARTIAL_RIGHT_FLAG = 64,
-      WRAP_ARY_FLAG = 128,
-      WRAP_REARG_FLAG = 256,
-      WRAP_FLIP_FLAG = 512;
-  /** Used to detect hot functions by number of calls within a span of milliseconds. */
-  var HOT_COUNT = 800,
-      HOT_SPAN = 16;
-  /** Used to indicate the type of lazy iteratees. */
-  var LAZY_FILTER_FLAG = 1,
-      LAZY_MAP_FLAG = 2,
-      LAZY_WHILE_FLAG = 3;
-  /** Used as references for various `Number` constants. */
-  var INFINITY = 1 / 0,
-      MAX_SAFE_INTEGER = 9007199254740991,
-      MAX_INTEGER = 1.7976931348623157e+308,
-      NAN = 0 / 0;
-  /** Used as references for the maximum length and index of an array. */
-  var MAX_ARRAY_LENGTH = 4294967295;
-  /** Used to associate wrap methods with their bit flags. */
-  var wrapFlags = [
-    ['ary', WRAP_ARY_FLAG],
-    ['bind', WRAP_BIND_FLAG],
-    ['bindKey', WRAP_BIND_KEY_FLAG],
-    ['curry', WRAP_CURRY_FLAG],
-    ['curryRight', WRAP_CURRY_RIGHT_FLAG],
-    ['flip', WRAP_FLIP_FLAG],
-    ['partial', WRAP_PARTIAL_FLAG],
-    ['partialRight', WRAP_PARTIAL_RIGHT_FLAG],
-    ['rearg', WRAP_REARG_FLAG]
-  /** `Object#toString` result references. */
-  var argsTag = '[object Arguments]',
-      arrayTag = '[object Array]',
-      asyncTag = '[object AsyncFunction]',
-      boolTag = '[object Boolean]',
-      dateTag = '[object Date]',
-      errorTag = '[object Error]',
-      funcTag = '[object Function]',
-      genTag = '[object GeneratorFunction]',
-      mapTag = '[object Map]',
-      numberTag = '[object Number]',
-      nullTag = '[object Null]',
-      objectTag = '[object Object]',
-      promiseTag = '[object Promise]',
-      proxyTag = '[object Proxy]',
-      regexpTag = '[object RegExp]',
-      setTag = '[object Set]',
-      stringTag = '[object String]',
-      symbolTag = '[object Symbol]',
-      undefinedTag = '[object Undefined]',
-      weakMapTag = '[object WeakMap]';
-  var arrayBufferTag = '[object ArrayBuffer]',
-      dataViewTag = '[object DataView]',
-      float32Tag = '[object Float32Array]',
-      float64Tag = '[object Float64Array]',
-      int8Tag = '[object Int8Array]',
-      int16Tag = '[object Int16Array]',
-      int32Tag = '[object Int32Array]',
-      uint8Tag = '[object Uint8Array]',
-      uint8ClampedTag = '[object Uint8ClampedArray]',
-      uint16Tag = '[object Uint16Array]',
-      uint32Tag = '[object Uint32Array]';
-  /** Used to match property names within property paths. */
-  var reIsDeepProp = /\.|\[(?:[^[\]]*|(["'])(?:(?!\1)[^\\]|\\.)*?\1)\]/,
-      reIsPlainProp = /^\w*$/,
-      rePropName = /[^.[\]]+|\[(?:(-?\d+(?:\.\d+)?)|(["'])((?:(?!\2)[^\\]|\\.)*?)\2)\]|(?=(?:\.|\[\])(?:\.|\[\]|$))/g;
-   * Used to match `RegExp`
-   * [syntax characters](http://ecma-international.org/ecma-262/7.0/#sec-patterns).
-  var reRegExpChar = /[\\^$.*+?()[\]{}|]/g;
-  /** Used to match leading and trailing whitespace. */
-  var reTrim = /^\s+|\s+$/g;
-  /** Used to match wrap detail comments. */
-  var reWrapComment = /\{(?:\n\/\* \[wrapped with .+\] \*\/)?\n?/,
-      reWrapDetails = /\{\n\/\* \[wrapped with (.+)\] \*/,
-      reSplitDetails = /,? & /;
-  /** Used to match backslashes in property paths. */
-  var reEscapeChar = /\\(\\)?/g;
-  /** Used to match `RegExp` flags from their coerced string values. */
-  var reFlags = /\w*$/;
-  /** Used to detect bad signed hexadecimal string values. */
-  var reIsBadHex = /^[-+]0x[0-9a-f]+$/i;
-  /** Used to detect binary string values. */
-  var reIsBinary = /^0b[01]+$/i;
-  /** Used to detect host constructors (Safari). */
-  var reIsHostCtor = /^\[object .+?Constructor\]$/;
-  /** Used to detect octal string values. */
-  var reIsOctal = /^0o[0-7]+$/i;
-  /** Used to detect unsigned integer values. */
-  var reIsUint = /^(?:0|[1-9]\d*)$/;
-  /** Used to compose unicode character classes. */
-  var rsAstralRange = '\\ud800-\\udfff',
-      rsComboMarksRange = '\\u0300-\\u036f',
-      reComboHalfMarksRange = '\\ufe20-\\ufe2f',
-      rsComboSymbolsRange = '\\u20d0-\\u20ff',
-      rsComboRange = rsComboMarksRange + reComboHalfMarksRange + rsComboSymbolsRange,
-      rsVarRange = '\\ufe0e\\ufe0f';
-  /** Used to compose unicode capture groups. */
-  var rsAstral = '[' + rsAstralRange + ']',
-      rsCombo = '[' + rsComboRange + ']',
-      rsFitz = '\\ud83c[\\udffb-\\udfff]',
-      rsModifier = '(?:' + rsCombo + '|' + rsFitz + ')',
-      rsNonAstral = '[^' + rsAstralRange + ']',
-      rsRegional = '(?:\\ud83c[\\udde6-\\uddff]){2}',
-      rsSurrPair = '[\\ud800-\\udbff][\\udc00-\\udfff]',
-      rsZWJ = '\\u200d';
-  /** Used to compose unicode regexes. */
-  var reOptMod = rsModifier + '?',
-      rsOptVar = '[' + rsVarRange + ']?',
-      rsOptJoin = '(?:' + rsZWJ + '(?:' + [rsNonAstral, rsRegional, rsSurrPair].join('|') + ')' + rsOptVar + reOptMod + ')*',
-      rsSeq = rsOptVar + reOptMod + rsOptJoin,
-      rsSymbol = '(?:' + [rsNonAstral + rsCombo + '?', rsCombo, rsRegional, rsSurrPair, rsAstral].join('|') + ')';
-  /** Used to match [string symbols](https://mathiasbynens.be/notes/javascript-unicode). */
-  var reUnicode = RegExp(rsFitz + '(?=' + rsFitz + ')|' + rsSymbol + rsSeq, 'g');
-  /** Used to detect strings with [zero-width joiners or code points from the astral planes](http://eev.ee/blog/2015/09/12/dark-corners-of-unicode/). */
-  var reHasUnicode = RegExp('[' + rsZWJ + rsAstralRange  + rsComboRange + rsVarRange + ']');
-  /** Used to identify `toStringTag` values of typed arrays. */
-  var typedArrayTags = {};
-  typedArrayTags[float32Tag] = typedArrayTags[float64Tag] =
-  typedArrayTags[int8Tag] = typedArrayTags[int16Tag] =
-  typedArrayTags[int32Tag] = typedArrayTags[uint8Tag] =
-  typedArrayTags[uint8ClampedTag] = typedArrayTags[uint16Tag] =
-  typedArrayTags[uint32Tag] = true;
-  typedArrayTags[argsTag] = typedArrayTags[arrayTag] =
-  typedArrayTags[arrayBufferTag] = typedArrayTags[boolTag] =
-  typedArrayTags[dataViewTag] = typedArrayTags[dateTag] =
GitHub sha: fd1ae16f
