FIX: wrong size DFP ads when using multiple sizes
getWidthAndHeight was being called twice for each ad placement: once when setting the size of the div, and once when calling the defineSlot API. getWidthAndHeight always advances to the next size in the list, so the wrong size ad would be inserted into the div.
diff --git a/assets/javascripts/discourse/components/google-dfp-ad.js.es6 b/assets/javascripts/discourse/components/google-dfp-ad.js.es6
index e742468..74e75b4 100755
--- a/assets/javascripts/discourse/components/google-dfp-ad.js.es6
+++ b/assets/javascripts/discourse/components/google-dfp-ad.js.es6
@@ -132,7 +132,15 @@ function getWidthAndHeight(placement, settings, isMobile) {
-function defineSlot(divId, placement, settings, isMobile, categoryTarget) {
+function defineSlot(
+  divId,
+  placement,
+  settings,
+  isMobile,
+  width,
+  height,
+  categoryTarget
   if (!settings.dfp_publisher_id) {
     return;
@@ -142,7 +150,6 @@ function defineSlot(divId, placement, settings, isMobile, categoryTarget) {
   let ad, config, publisherId;
-  let size = getWidthAndHeight(placement, settings, isMobile);
   if (isMobile) {
     publisherId = settings.dfp_publisher_id_mobile || settings.dfp_publisher_id;
@@ -154,7 +161,7 @@ function defineSlot(divId, placement, settings, isMobile, categoryTarget) {
   ad = window.googletag.defineSlot(
     "/" + publisherId + "/" + settings[config.code],
-    [size.width, size.height],
+    [width, height],
     divId
@@ -170,7 +177,7 @@ function defineSlot(divId, placement, settings, isMobile, categoryTarget) {
   ad.addService(window.googletag.pubads());
-  ads[divId] = { ad: ad, width: size.width, height: size.height };
+  ads[divId] = { ad: ad, width: width, height: height };
   return ads[divId];
@@ -228,6 +235,17 @@ export default AdComponent.extend({
   loadedGoogletag: false,
   refreshOnChange: null,
   lastAdRefresh: null,
+  width: Ember.computed.alias("size.width"),
+  height: Ember.computed.alias("size.height"),
+  @computed()
+  size() {
+    return getWidthAndHeight(
+      this.get("placement"),
+      this.siteSettings,
+      this.site.mobileView
   @computed(
     "siteSettings.dfp_publisher_id",
@@ -332,7 +350,6 @@ export default AdComponent.extend({
       categorySlug = this.get("currentCategorySlug");
     if (this.get("loadedGoogletag")) {
-      // console.log(`refresh(${this.get("divId")}) from updated()`);
       this.set("lastAdRefresh", new Date());
       window.googletag.cmd.push(() => {
         ad.setTargeting("discourse-category", categorySlug || "0");
@@ -350,19 +367,21 @@ export default AdComponent.extend({
     loadGoogle(this.siteSettings).then(() => {
       this.set("loadedGoogletag", true);
         let slot = defineSlot(
           this.get("divId"),
           this.siteSettings,
           this.site.mobileView,
+          this.get("width"),
+          this.get("height"),
           this.get("currentCategorySlug") || "0"
         if (slot && slot.ad) {
           // Display has to be called before refresh
           // and after the slot div is in the page.
           window.googletag.display(this.get("divId"));
-          // console.log(`refresh(${this.get("divId")}) from _initGoogleDFP()`);
           window.googletag.pubads().refresh([slot.ad]);
@@ -375,14 +394,6 @@ export default AdComponent.extend({
     if (!this.get("showAd")) {
       return;
-      this.get("placement"),
-      this.siteSettings,
-      this.site.mobileView
-    this.set("width", size.width);
-    this.set("height", size.height);
   @on("willDestroyElement")
GitHub sha: 3aa9cb8a
