Fixed test suite with PREFABRICATION=0 (#7574)
The issue here was that, with prefabrication, bumped_at was being persisted and then loaded and the DB was storing it with less precision than the object state.
diff --git a/spec/models/topic_spec.rb b/spec/models/topic_spec.rb
index 98b5fb1..cdb8b4a 100644
--- a/spec/models/topic_spec.rb
+++ b/spec/models/topic_spec.rb
@@ -932,7 +932,7 @@ describe Topic do
         it 'should not be visible and have correct counts' do
           expect(topic).not_to be_visible
           expect(topic.moderator_posts_count).to eq(1)
-          expect(topic.bumped_at.to_f).to eq(@original_bumped_at)
+          expect(topic.bumped_at.to_f).to be_within(1e-4).of(@original_bumped_at)
@@ -946,7 +946,7 @@ describe Topic do
         it 'should be visible with correct counts' do
           expect(topic).to be_visible
@@ -961,7 +961,7 @@ describe Topic do
         it "doesn't have a pinned_at but has correct dates" do
           expect(topic.pinned_at).to be_blank
@@ -974,7 +974,7 @@ describe Topic do
         it 'should enable correctly' do
           expect(topic.pinned_at).to be_present
@@ -992,7 +992,7 @@ describe Topic do
         it 'should archive correctly' do
           expect(@archived_topic).not_to be_archived
-          expect(@archived_topic.bumped_at.to_f).to be_within(0.1).of(@original_bumped_at)
+          expect(@archived_topic.bumped_at.to_f).to be_within(1e-4).of(@original_bumped_at)
           expect(@archived_topic.moderator_posts_count).to eq(1)
@@ -1007,9 +1007,8 @@ describe Topic do
         it 'should be archived' do
           expect(topic).to be_archived
@@ -1025,9 +1024,8 @@ describe Topic do
         it 'should not be pinned' do
           expect(@closed_topic).not_to be_closed
           expect(@closed_topic.moderator_posts_count).to eq(1)
-          expect(@closed_topic.bumped_at.to_f).not_to eq(@original_bumped_at)
+          expect(@closed_topic.bumped_at.to_f).not_to be_within(1e-4).of(@original_bumped_at)
       context 'enable' do
@@ -1039,7 +1037,7 @@ describe Topic do
         it 'should be closed' do
           expect(topic).to be_closed
           expect(topic.topic_timers.first).to eq(nil)
GitHub sha: cac7e43b
