GITHUB_TOKEN is not required
diff --git a/README.md b/README.md
index acf3b59..77b81cf 100644
--- a/README.md
+++ b/README.md
@@ -1,10 +1,9 @@
 # GitHub Action - Publish Gem to Rubygems
-This is a GitHub Action written to streamline the Ruby gem publication process. The action sets the Gem Credentials from `GITHUB_TOKEN` and `RUBYGEMS_API_KEY`secrets, and then runs `rake release` in your project root. You can override this command by setting `RELEASE_COMMAND` environment variable to the script that creates and publishes (this is usually only the case when a repository hosts multiple gems together).
+This is a GitHub Action written to streamline the Ruby gem publication process. The action sets the Gem Credentials using `RUBYGEMS_API_KEY` secret and then runs `rake release` in your project root. You can override this command by setting `RELEASE_COMMAND` environment variable to the script that creates and publishes (this is usually only the case when a repository hosts multiple gems together).
 # Secrets Needed
-`GITHUB_TOKEN` - Bundler needs this to create tags on your repo for the release.
 `RUBYGEMS_API_KEY` - The Rubygems API Key for an Owner of the Gem you wish to publish. You can find your API Key by looking in `~/.gem/credentials` or using the [Rubygems API](https://guides.rubygems.org/rubygems-org-api/#misc-methods).
 # Environment Variables
@@ -40,7 +39,6 @@ jobs:
       - name: Release Gem
         uses: discourse/publish-rubygems-action@v2-beta
         env:
-          GITHUB_TOKEN: ${{ secrets.GITHUB_TOKEN }}
           RUBYGEMS_API_KEY: ${{ secrets.RUBYGEMS_API_KEY }}
           RELEASE_COMMAND: rake release
           GIT_EMAIL: ci@example.com
diff --git a/entrypoint.sh b/entrypoint.sh
index 8afbb81..30a31b4 100755
--- a/entrypoint.sh
+++ b/entrypoint.sh
@@ -6,7 +6,6 @@ mkdir -p ~/.gem
 cat << EOF > ~/.gem/credentials
-:github: Bearer ${GITHUB_TOKEN}
 :rubygems_api_key: ${RUBYGEMS_API_KEY}
 EOF
GitHub sha: 25a46441b946736be9aec868d0fb6f8057137033
This commit appears in #2 which was approved by davidtaylorhq. It was merged by CvX.
