Improve details_enabled site setting description copy (#12560)
The details_enabled
site setting description did not clearly convey what it controls.
The copy change was discussed here: https://meta.discourse.org/t/183923
diff --git a/plugins/discourse-details/config/locales/server.en.yml b/plugins/discourse-details/config/locales/server.en.yml
index 0e78331..a616075 100644
--- a/plugins/discourse-details/config/locales/server.en.yml
+++ b/plugins/discourse-details/config/locales/server.en.yml
@@ -1,5 +1,5 @@
en:
site_settings:
- details_enabled: 'Enable the details feature. If you change this, you must rebake all posts with: "rake posts:rebake".'
+ details_enabled: 'Include the ability to add expandable details to a post. This feature can be found in the toolbar popup menu of the composer. You must rebake all posts with "rake posts:rebake" if you change this setting.'
details:
excerpt_details: "(click for more details)"
GitHub sha: c672ee28
